Diffraction and interference patterns
The discussion revolves around the interference patterns observed in Young's double slit experiment and the relationship between these patterns and single slit diffraction effects.
  • Participants explore how single slit diffraction is considered in the context of double slit interference, questioning the assumptions regarding slit width and separation.
Some participants have provided insights into the relationship between single slit diffraction and double slit interference, suggesting that the dominance of one effect over the other can depend on the relative dimensions of the slits. There is acknowledgment of the complexity in accurately accounting for both effects.
There is mention of potential inaccuracies in reasoning regarding the relative widths of the slits, indicating that assumptions about the idealization of slits may be under discussion.
nokia8650
In Young's double slit experiment, how come the interefernece pattern produced does not take into account single slit diffraction?
Thanks
It does. It is just that since (if) the slit separation is substantially greater than the slit widths this factor dominates. You can however do a more precise calculation which takes both effects into account.
[edit: PS] My reasoning may not quite be right w.r.t. relative widths but the rest is correct.[ end edit]
I agree with jambaugh. Another way of saying it is that, for a single slit difraction patern, you assume that the width of the slit is nonnegligible, whereas, for a double slit pattern, you assume that the slits are infinitesimals, like ideal line sources with zero width.
That makes sense, thanks!
  • · Replies 34 ·
