What is the Surface Current and Magnetic Field for a Rotating Charged Disc?
The discussion focuses on calculating the surface current density K(x,y) and the magnetic field generated by a uniformly charged rotating disc with radius R and total charge Q, rotating at a constant angular velocity w. For part (a), the surface current density is expressed as K(r, φ) in cylindrical coordinates, where r = √(x² + y²) and φ = tan⁻¹(y/x). In part (b), the magnetic field at point r = sk and r = -sk is determined using the Biot-Savart law, which relates current distributions to magnetic fields.
  • Understanding of electromagnetic theory, specifically the Biot-Savart law.
  • Familiarity with cylindrical coordinates and their applications in physics.
  • Knowledge of angular momentum and its relation to rotating systems.
  • Basic concepts of current density and charge distribution.
  • Study the Biot-Savart law in detail to understand its application in calculating magnetic fields.
  • Learn about angular momentum in rotating systems and its implications for charged particles.
  • Explore the conversion between Cartesian and cylindrical coordinates for complex geometries.
  • Investigate the properties of surface current densities in electromagnetic fields.
Students and professionals in physics, particularly those studying electromagnetism, as well as engineers working with rotating charged systems and magnetic field calculations.
lovinuz
There is a disc with radius R which has a uniformly-distributed total charge Q, rotating with a constant angular velocity w.
(a) in a coordinate system arranged so that the disc lies in the xy plane with its center at the origin, and so that the angular momentum point in the positive z direction, the local current density can be written J(x,y,z) = K(x,y) d(z). determine the surface current K(x,y) in terms of Q, w, and R.
(b) using the law of Biot and Savart, determine the magnetic field at point r=sk, k is the vector direction. find the same for r=-sk.
i might add that we can use cylindrical coordinates, expressing this as K(r,phi) where r=sqrt(x square + y square) and phi = tan inverse (y/x). this is for part (a).
  • · Replies 16 ·
