Wave function/Infinite square well confusion
The discussion revolves around a particle in the ground state of a one-dimensional infinite square well, specifically focusing on the initial wave function \(\Psi(x,0)\) and the implications of boundary conditions and normalization in quantum mechanics.
  • The original poster attempts to understand the relationship between the wave function and the known energy state, questioning whether the coefficient \(c_1\) should be set to 1 due to normalization. Other participants discuss the necessity of boundary conditions and the implications of initial values in the context of quantum mechanics.
Participants are exploring the concepts of normalization and boundary conditions, with some guidance offered regarding the normalization of the wave function. There is acknowledgment of confusion regarding the initial conditions and the nature of the wave function in this context.
There is a mention of the need for boundary conditions as inputs for the differential equation governing the system, highlighting the complexity of determining the initial wave function without additional information.
Salviati
"A particle of mass m is in the ground state of a one-dimensional infinite square well with walls at x=0 and x=a.
[tex]\psi_1(x) =\sqrt{\frac{2}{a}}sin(\frac{\pi x}{a})[/tex],
E1=[tex]\frac{h^2\pi ^2}{2ma^2}[/tex]*
What is the initial wave function [tex]\Psi(x,0)?[/tex]
*[tex]h[/tex] is supposed to be h bar, I just couldn't find it)
My attempt: If the general solution is a superposition of all stationary states, [tex]\Psi(x,t)=\sum c_n\psi_ne^\frac{-iE_nt}{h}[/tex], at t=0, [tex]\Psi(x,0)=\sum c_n\psi_n[/tex]. Also, at this time, the particle is in the ground state (n=1), so: [tex]\Psi(x,0)=c_1\psi_1[/tex]. Do I assume c1=1 at this point, because the wave function "collapses" once the energy becomes known? I'm just not sure if I understand exactly what happens when the known data is given.
The solution itself is supposed to be [tex]\Psi(x,0)=\psi_1(x) =\sqrt{\frac{2}{a}}sin(\frac{\pi x}{a})[/tex].
c1=1 by normalization, assuming that [tex]\Psi(x,t)[/tex] is normalized. For a more general initial state,
[tex]\sum_{n=1}^\infty |c_n|^2=1.[/tex]
You are right to be confused. You cannot know the answer to this question; that is the whole idea behind boundary conditions/initial values: they are INPUTS. For a first-order differential equation (like (d/dt)psi=iHpsi), you need one input BC for each degree of freedom.
Try \hbar.
Thanks guys.
turin said:
Try \hbar.
[tex]\hbar[/tex] :redface:
  • · Replies 39 ·
16K
