| Thread Closed |
Bending equation, can someone check my answer? |
Share Thread | Thread Tools |
| Dec9-08, 05:25 AM | #1 |
The cross-section of an idealised I section beam has overall dimensions 12mm x 240mm deep. If the web and Flange are both 25mm Thick, determine the second moment of area of the section. If the maximum bending stress is limited to 100MN/m2, determine the maximum bending moment the beam can withstand 2. Relevant equations ∂ = Stress Applied Y = Distance form Neutral Axis M = Applied moment I = Second moment of area E = Youngs modulus R = Radius (measured to neutral axis) (∂/y) = (M/I) = (E/R) I = b . (d^3) ---------- 12 Y = depth/2 3. The attempt at a solution I = b . (d^3) ---------- 12 b= 125-25 = 95 d= 240-50 = 190 I = [0.095 . (0.19^3)] / 12 = 5.4x10^-5 (∂/y) = (M/I) 100x10^6 = M ____________ _____________ {(.24/2)=0.12} {5.43x10^-5} 100x10^6 ---------- x 5.43x10^-5 = M 0.12 M= 45000nm 45KNM Is this correct. Mike Also i've just tryed the next (and last) one Which i have no clue about. A steel bar of rectangular cross-section is bent into a circular arc of 15m. The with of the cross-section is twice its depth. If the maximum stress due to bending is 60MN/m2, determine the dimensions of the section and the magnitude of the applied moment. Take young's modulus as 200GN/m2 Dont even no where to start on that one Mike |
| Dec9-08, 12:02 PM | #2 |
The formula I=bd^3/12 applies to a rectangular shape only. You have to compute the I of each of the 3 rectangles that comprise the section, and use the parallel axis theorem to get the I of the beam. Are you familiar with it?
| Dec9-08, 02:02 PM | #3 |
I though something was wrong.
I think i've seen the equation but carnt find it in my notes? Do you have it? Mike |
| Dec9-08, 02:16 PM | #4 |
Basically, the moment of inertia of the section about its neutral axis is equal to sum of the moments of inertia of each rectangle, abouts its centroid, plus the sums of the (area of each rectangle times the square of the distance from its centroid to the neutral axis). From symmetry, the neutral axis is thru the middle of the beam. [tex] I_x = \Sigma I_n + A_nd^2[/tex]. Please show your work in calculating this expression.
| Thread Closed |
| Tags |
| bending, bending moment, equation, equations of motion |
| Thread Tools | |
Similar Threads for: Bending equation, can someone check my answer?
| can someone check my answer? | Introductory Physics Homework | 2 | ||
| Equation of a plane that passes thorugh the line of intersection of...[answer check] | Calculus & Beyond Homework | 2 | ||
| Answer Check - Find an equation of the tangent line | Calculus & Beyond Homework | 1 | ||
| Could Someone Check This Answer? | Introductory Physics Homework | 4 | ||
| answer check please | Introductory Physics Homework | 2 | ||
