Earths Energy & rate of absorbtion
The discussion centers on calculating the rate of solar energy absorption by a shallow dish placed on Earth's surface, specifically a dish with a surface area of 0.039 m². The solar constant is given as 1370 W/m², leading to an absorption rate of 53.43 W for the dish. Additionally, the discussion explores the energy required to melt 0.59 kg of ice and raise the temperature of the resulting water to 4.5 °C, utilizing specific heat capacity and latent heat formulas. Key calculations involve determining energy absorbed and the time required for the phase change and temperature increase.
  • Understanding of solar radiation concepts, specifically solar constant.
  • Knowledge of energy absorption calculations, including area and power.
  • Familiarity with specific heat capacity and latent heat equations.
  • Basic skills in unit conversion and dimensional analysis.
  • Research the implications of solar constant variations on energy absorption.
  • Learn about the principles of heat transfer in phase changes.
  • Explore advanced calculations involving energy transformations in thermodynamics.
  • Investigate the effects of surface area on energy absorption rates in different materials.
Students studying physics, particularly those focusing on thermodynamics and energy transfer, as well as educators looking for practical examples of energy absorption calculations.
dukg08
(a)
Virtually all of the energy used on Earth derives originally from the Sun and solar radiation is intercepted at 1370 W m−2 at the top of the atmosphere, and that 49% of this radiation is absorbed by the Earth’s surface. Assuming that a shallow dish containing ice or water, placed on the Earth’s surface, absorbs the same fraction of solar radiation as the surface itself, at what rate is energy absorbed from the Sun by such a container of surface area 0.039 m2? Make sure you show your working.
(b)
A student, keen to investigate the energy transformations, places a shallow dish of ice outside in the sun. The ice has a mass of 0.59 kg and a surface area of 0.039 m2. Assuming that the ice is originally at 0 °C and using your answer to part (a), for how long does the student have to wait until all the ice is melted and the temperature of the resulting water has reached 4.5 °C?
You may assume that the specific heat capacity of water, c, is 4.2 × 103 J kg−1 °C−1 and that the specific latent heat of melting of water, Lf, is 3.3 × 105 J kg−1 .
You should identify clearly the three main steps in your answer (‘Decide how you are going to tackle the problem’; ‘Do the calculation’; ‘Check that your answer makes sense’).
none given
(a)
solar constent x area
1370x3.9x10-2 = 53.43
but how is rate of absorption worked out?
(b)
melting -> q=Lfm -> 0.59 x 3.3x105 = 194700 J
temp raise -> q=mcT -> 0.59 x 4.2x103 x 4.5 = 11151 J
length of time -> ?
The write of 'Decide how you are going to tackle the problem’; ‘Do the calculation’; ‘Check that your answer makes sense’ will come later.
Hi dukg08,
Look at your units. What is the unit W representative of? What is the unit for energy? How are these related?
  • · Replies 21 ·
