Emperical Formula for hydrate
  • Thread starter Thread starter Xenon100
    Formula
The discussion focuses on determining the empirical formula of magnesium sulfate hydrate through various methods. The primary method suggested involves evaporating water from the hydrate to measure the masses of the anhydrous salt and water separately. An alternative method proposed is using a precipitation reaction to form a solid, allowing for stoichiometric calculations to deduce the mass of the anhydrous magnesium sulfate. The importance of ensuring the salt does not decompose during the process is also emphasized.
  • Understanding of empirical formulas and stoichiometry
  • Familiarity with magnesium sulfate (MgSO4) and its hydrates
  • Knowledge of laboratory techniques for mass measurement and filtration
  • Basic principles of chemical reactions and precipitate formation
  • Research methods for calculating empirical formulas from mass data
  • Learn about precipitation reactions and their applications in quantitative analysis
  • Study the properties and behavior of magnesium sulfate hydrates
  • Explore techniques for ensuring the integrity of chemical compounds during heating
Chemistry students, laboratory technicians, and educators involved in analytical chemistry and empirical formula determination will benefit from this discussion.
Xenon100
I have a lab in which I need to devise my own procedure for calculating the emperical formula of magnesium sulfate hydrate. I have done some research and found out that the simplest way to find it would be through evaporating the water off the hydrate, calculating the masses of the anyhydrous salt and water separately and then, dividing the mass values to find the simple formula ratio.
So My question is: Is it possible to use another method beside evaporating the water in order to find the Emperical Formula? Can I use a precipitate method to calculate the Emperical Formula?(As in I add some of the magnesium sulfate hydrate into water and then I mix it with another solution that will then form a precipitate.)
My idea is that I can calculate the mass of the precipitate I formed, filter it, dry it, and then use stochiometry to at least find the mass of the anhydrous magnesium sulfate. However, I'm curious as to how I would find then calculate the mass of the water molecules. If you have any suggestions at all, please reply
Thanks for your help
If you know initial mass of the sample, and amount of MgSO4 in it, you can calculate mass of water, don't you?
You first idea was OK, although sometimes it won't work. You have to be sure if your salt didn't decompose on roasting.
9K
18K
109K
