Sailing Through Space: The Technical Challenges of Interstellar Travel
The discussion revolves around the technical challenges of interstellar travel, particularly focusing on the concept of using solar sails and radiation pressure for propulsion. Participants explore the feasibility of sailing spacecraft navigating between solar systems and the implications of radiation pressure from different stars.
  • One participant questions the ability of a sailing spacecraft to reach another solar system, suggesting that radiation pressure from the target star would oppose the ship's trajectory.
  • Another participant introduces the concept of tacking, stating that sailing ships can effectively navigate downwind and that a similar principle applies to solar sails.
  • A participant argues that building speed without carrying fuel is advantageous, drawing historical parallels to advancements in sailing technology and practical navigation methods.
  • Concerns are raised about the mechanics of tacking in space, particularly the need for a force analogous to water against a keel, and how gravity could serve as a second force for maneuvering closer to a star.
  • One participant notes that solar sails are primarily considered for interplanetary travel rather than interstellar, pointing out that radiation pressure weakens with distance from the Sun.
  • A participant discusses realistic proposals for interstellar travel, mentioning the limitations of current solar sail technology and the need for advanced propulsion methods to achieve significant fractions of the speed of light.
  • Deceleration challenges are highlighted, with references to proposed methods for slowing down a spacecraft, including the use of second-stage sails and superconducting magnetic sails.
Participants express a range of views on the feasibility and mechanics of using solar sails for interstellar travel, with no consensus reached on the effectiveness of current proposals or the practicality of the concepts discussed.
Limitations include unresolved assumptions about the mechanics of tacking in space, the effectiveness of solar sails at various distances from stars, and the technical challenges associated with deceleration methods.
_F_
I have read about interstellar "sailing ships" that rely on radiation presuure.
My question is not really technical, just something to mull over. But I figure that if we set a sailing spacecraft from earth, I don't think it will be able to get to another solar system.
Sailing ships use radiation pressure as their "wind," so leaving away from the Sun is no problem, but what about entering back into another solar system? Won't that sun send its radiation pressure in the opposite direction of the ship? What then? After years of sailing will the ship just settle with some median distance between stars?
The only way I can think of to avoid this is if the ship had enough velocity and enough momentum that the target star could only slow down the ship until it reached its destination (hopefully a planet!). Otherwise, I don't see any other way around it.
Thanks.
Astronomy news on Phys.org
You can sail a ship downwind via tacking. In fact, sailing ships can go a lot faster downwind than upwind. The same concept applies to solar sails.
I think it is the only way to go. You can build up speed indefinitely, not carry fuel and not waste any in friction in space.
I always think of this example of tacking against the wind as an example of "practical men". It was obvious to practical men for millenia that you could only sail downwind. Correct me if I am wrong but that is much what they did for millenia and only mastered the opposite a century or two before Columbus? Same as they only developed harnesses allowing horses to pull their full force in late middle ages or later, and Inuit and Amerindian dog harnesses only allowed a fraction of the possible effort? States and Empires lived by sailing and now it is only a sport yet sailing technology has advanced more in the past half century than in several previous? (Hopefully it will make a comeback).
So I remember reading but correct me if wrong. Then to be fair I have to recognise there are practical men and practical men.
For a water-borne ship, don't you need the force of the water against the keel of the boat in order to tack? If so, how would you accomplish something similar with a spacecraft ?
I think the idea is to use the force of gravity as the “second force”. To move closer to a sun, the spacecraft would adjust the tacking angle so the solar force is opposite to the direction that the craft is orbiting. This reduces the velocity of the orbit, allowing the craft to move closer. Just the opposite method allows the craft to move farther. The actual mechanics involved is quite complicated, but this is the basic idea.
I think you might have that backward.
Also, solar sails are not generally thought of as a means for interstellar travel, but only for interplanetary travel within the solar system. And even then, it is mostly an " inner planets" type of thing. As you get further from the sun, out toward the outer planets, the radiation pressure from the sun becomes too weak.
However, if radiation pressure from a star were used to propel a craft to another star, then the radiation from that other star would probably be used for breaking.
The only `realistic' proposals for interstellar spaceflight using solar sails that I'm aware of (near-solar manoeuvres + gravity assist) are just barely capable of attaining 0.01 c.
That puts a lower bound of 430 y to the nearest star, which is not known to harbour any interesting planets.
To travel any further than that, you really need go ultra-relativistic (> 0.1 c). The only semi-realistic way to achieve that is laser light sail propulsion, particle-beam-propelled magnetic sails or more likely, hybrid methods such as Jordin Kare's `sailbeam' concept (laser-accelerated beams of dielectric microsails reflected by magnetic sails).
Decelerating is troublesome. Proposals have been put forth by Robert Forward for `second-stage' sails which back-reflect laser light to decelerate the first stage, but this proves nearly impossible. Deceleration can be overcome, however, if high-temp superconducting magnetic sails can be constructed to `break' against (inter)stellar wind + high energy density propulsion such as direct matter-antimatter annihilation.
  • · Replies 22 ·
  • · Replies 118 ·
13K
  • · Replies 22 ·
  • · Replies 24 ·
