Evaluate Integral: \int_{-2}^{2} \sqrt{4 - x^2} \ dx
  • Thread starter Thread starter newabb
    Integral
The discussion revolves around evaluating the integral \(\int_{-2}^{2} \sqrt{4 - x^2} \ dx\), which is related to the area under a semicircle in the context of calculus.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants explore trigonometric substitution and the properties of even functions to simplify the integral. There are discussions about changing limits of integration and the implications of variable substitution.
Some participants have offered guidance on recognizing the integral's geometric interpretation as the area of a semicircle. There is ongoing exploration of the correct evaluation methods, with various interpretations being discussed.
Participants note the importance of correctly changing limits during substitution and the potential confusion between radians and degrees in the context of the integral's evaluation.
newabb
Hi,
Can anyone tell me if the following of my integration is right or wrong?
[tex] \int_{-2}^{2} \sqrt{4 - x^2} \ dx[/tex]
let
[tex]x = 2 sin \theta[/tex]
then
[tex]\frac{dx}{d\theta}=2cos\theta, \ dx=2cos\theta \ d\theta[/tex]
also
[tex]4-x^2 = 4-(2sin\theta)^2<br /> = 4 - 4sin^2\theta = 4(1-sin^2\theta)=4cos^2\theta[/tex]
thus
[tex] \sqrt{4-x^2}=\sqrt{4cos^2\theta}[/tex]
[tex]\int_{-2}^{2} \sqrt{4 - x^2} \ dx[/tex]
[tex]= \int_{-2}^{2} \sqrt{4cos^2\theta} \ (2cos\theta \ d\theta)[/tex]
[tex]= \int_{-2}^{2} 2cos\theta \ (2cos\theta \ d\theta)[/tex]
[tex]= 4\int_{-2}^{2} cos^2\theta \ d\theta[/tex]
[tex]= 4\int_{-2}^{2} \frac{1+cos2\theta}{2} \ d\theta[/tex]
[tex]= \frac{4}{2} \int_{-2}^{2} (1+cos2\theta) \ d\theta[/tex]
let [tex]u=2\theta[/tex] then [tex]\frac{du}{d\theta}=2, \ d\theta = \frac{1}{2}du[/tex]
[tex]= 2 \int_{-2}^{2} (1+cos2\theta) \ d\theta[/tex]
[tex]= 2 \int_{-2}^{2} (1+cos \ u) \ (\frac{1}{2}du)[/tex]
[tex]= \frac{2}{2}\int_{-2}^{2} (1+cos \ u) \ du[/tex]
[tex]= \int_{-2}^{2} (1+cos \ u) \ du[/tex]
[tex]= u + sin \ u]^{2}_{-2}[/tex]
[tex]= 2\theta + sin2\theta]^{2}_{-2}[/tex]
[tex]= [2(2) + sin2(2)] - [2(-2) + sin2(-2)][/tex]
[tex]= (4 + sin4) - [-4 + sin(-4)][/tex]
[tex]= 4 + sin4 + 4 - sin(-4)[/tex]
[tex]= 8 + sin4 - sin(-4)[/tex]
[tex]= 8 + 0.07 - (-0.035)[/tex]
[tex]= 8 + 0.07 + 0.035[/tex]
[tex]= 8.105[/tex]
Thenk you very much for evaluating
Your integration is wrong, but no worries.
First of all, notice that your integrand is an even function, which means that you can change your integral to [tex]2\int_{0}^{2} \sqrt{4 - x^2} \ dx[/tex] to make things (slightly) easier.
However, the crucial mistake you made is forgetting to change the limits of integration when you switched the variables x and theta. The choice of substitution is fine and your algebra also looks good. Just remember x = 2sin(theta) => theta = arcsin(x/2) so use this to change your limits of integration.
Your final answer should be very nice (a multiple of pi in fact).
Alternatively, interpret the integral geometrically and the answer is immediate.
Hi,
Thank you for the tips.
[tex]x = 2 \ sin\theta[/tex]
for [tex]x=2[/tex]:
[tex]2 = 2 \ sin\theta[/tex]
[tex]sin\theta=\frac{2}{2}=1[/tex]
[tex]\theta=sin^{-1}(1)=\frac{\pi}{2}[/tex]
for [tex]x=-2[/tex]
[tex]-2=2 \ sin\theta[/tex]
[tex]sin\theta = \frac{-2}{2}=-1[/tex]
[tex]\theta=sin^{-1}(-1)=-\frac{\pi}{2}[/tex]
Thus
[tex]\int^{2}_{-2}\sqrt{4-x^2} \ dx = 4\int^{\frac{\pi}{2}}_{-\frac{\pi}{2}}cos^2\theta \ d\theta[/tex]
[tex]\vdots[/tex]
[tex]=2\theta+sin2\theta]^{\frac{\pi}{2}}_{-\frac{\pi}{2}}[/tex]
[tex]=[2(\frac{\pi}{2})+sin2(\frac{\pi}{2})]-[2(-\frac{\pi}{2})+sin2(-\frac{\pi}{2})][/tex]
[tex]=(\pi+sin\pi})-[-\pi+sin(-\pi)][/tex]
[tex]=\pi+sin\pi+\pi-sin(-\pi)[/tex]
[tex]=\pi+sin\pi+\pi-(-sin\pi)[/tex]
[tex]=\pi+sin\pi+\pi+sin\pi[/tex]
[tex]=2\pi+2 \ sin\pi[/tex]
[tex]=2\pi+2 \ (0)[/tex]
[tex]=2\pi[/tex]
[tex]=2 \ (180)[/tex]
[tex]=360[/tex]
Would anybody please evaluate it again
Thanks
If you convert radians to degrees, make it clear because [tex]\pi[/tex] does not equal 180.
Use Anthony's advice to check your answer. Hint: the integral represents a semicircle.
hmm...
[tex]2\pi = 2\times3.14=6.28[/tex]
Is that correct?
Thanks for your help
divided by 2 for half the area, so pi
no lubuntu, he didn't need too, if you look at that integral, it's the area of a semicircle, if he had multiplied by 2 to get a full circle, he would have had to divide by 2, but he didn't, It looks correct as far as I can tell
newabb said:
hmm...
Is that correct?
[tex]2\pi[/tex] is correct. The other two are only correct to two decimal places.
  • · Replies 20 ·
  • · Replies 19 ·
