How Does a Rod's Angular Velocity Relate to Its Movement in the X-Y Plane?
  • Thread starter Thread starter suhaskowshik_92
    Plane Rod
The discussion focuses on calculating the angular velocity of a rod AB, which is 2 meters long and positioned in the horizontal x-y plane. Given the velocities of the ends A and B, specifically v_a = 2i + v_y j and v_b = 2i + 6j, and the angle of 30 degrees with the x-axis, the problem requires determining the magnitude of the angular velocity, the value of v_y, and the component of the center of mass's velocity perpendicular to the rod. The calculations involve applying the principles of angular motion and vector analysis.
  • Understanding of angular velocity and its calculation
  • Familiarity with vector components in two-dimensional motion
  • Knowledge of kinematics in the x-y plane
  • Basic trigonometry, particularly relating to angles and triangles
  • Study the principles of angular motion and angular velocity calculations
  • Learn about vector decomposition and how to resolve velocities into components
  • Explore kinematic equations in two-dimensional motion
  • Investigate the relationship between linear and angular motion in rigid bodies
Students studying physics, particularly those focusing on mechanics, as well as educators and tutors looking to enhance their understanding of angular motion in two dimensions.
suhaskowshik_92
A rod AB of length 2m moves in horizontal x-y plane. at any instant end A of rod is at origin and has velocity v_a =2i +v_y j. the other end B at the same instant is moving with velocity v_b = 2i +6j. the rod makes an angle of 30 degrees with the x-axis at this instant. find:
1. the magnitude of angular velocity of the rod.
2. value of v_y .
3. the component of velocity of cetre of mass in the direction perpendicular to the rod at given instant.
You have to show us an attempt to solve the problem.
i don't know how to do
  • · Replies 22 ·
  • · Replies 24 ·
