Calculating Bullet Height: Moon vs Earth | Time to Reach Maximum Displacement
  • Context: Undergrad
  • Thread starter Thread starter PrudensOptimus
The discussion revolves around calculating the height a bullet would reach when fired straight up from the surfaces of the Moon and Earth, as well as the time taken for the bullet to return to the ground in both scenarios. It includes mathematical reasoning and questions about the correctness of the calculations and assumptions made.
  • Mathematical reasoning, Technical explanation, Debate/contested
  • Post 1 presents equations for the height of a bullet fired from the Moon and Earth, suggesting it takes 160 seconds on the Moon and 26 seconds on Earth to return to the ground.
  • Post 1 raises a second question about finding acceleration when velocity is zero, providing calculations for specific times.
  • Post 2 agrees with the second question's answer but points out discrepancies in the first question's equations and suggests that the derivatives provided are incorrect.
  • Post 2 questions the clarity of the problem statement regarding maximum height and the presence of time in the equations.
  • Post 5 acknowledges a typo in the equations and discusses the implications of free fall acceleration on the Moon, suggesting that the initial calculations may not make sense given known values of gravitational acceleration.
  • Post 6 confirms the correctness of the second question's answer and notes that the equations are in feet per second, which affects the interpretation of the results.
  • Post 7 suggests a simpler approach to solving the first question without calculus and questions the assumption about the bullet's velocity upon returning to the surface.
Participants express differing views on the correctness of the initial calculations and the interpretation of the equations. There is no consensus on the validity of the assumptions made regarding the equations or the physical principles involved.
There are unresolved questions about the accuracy of the equations provided, the assumptions regarding gravitational acceleration on the Moon, and the interpretation of velocity at the point of return to the surface.
PrudensOptimus
A bullet fired straight up from the moon's surface would reach a height of s = 832t - 2.6t^2 after t sec. On Earth, in the absence of air, its height would be s = 832t - 16t^2 after t sec. How long would it take the bullete to get back down in each case?
On Moon:
It would take the same amount of time to get down as it took to go up(maximum displacement, when v = 0).
Thus, V(t) = ds/dt = 832 - 5.2t = 0. t = 160s. It would take about 2 minutes and 40 seconds.
On Earth:
Same notion. V(t) = ds/dt = 832 - 32t = 0. t = 26s.
-- Am I right?
Question 2:
The position of a body at time t sec is s = t^3 - 6t^2 +9t meters. Find the body's acceleration each time the velocity is 0.
Because V(t) = ds/dt = 3t^2 - 12t + 9,
a(t) = dv/dt = 6t - 12
Particle has v = 0 at t = 3, and 1 sec
Thus, the particle has acelleration at v = 0 at:
a(3) = 6 m/s^2
and
a(1) = -6 m/s^2
-- Am I right?
Please correct my mistake. Thanks.
#2 looks right.
#1, a few discrepancies...
First of all, if the position functions are really as you typed them:
s = 832 - 2.6t^2
and
s = 832 - 16t^2
then your derivatives are wrong because there is no t in the first term of each equation.
On the other hand, the problem, as you posted it, doesn't say that s is the MAXIMUM height, and it also isn't clear whether there are two different s's, or only one value of s...
On the other hand, there really should be a t in the first term, since the usual position function is s = v0t - .5at^2
So should it say s = 832t - 16t^2?
On the other hand, maybe the trick is that the t is "hidden" such that 832 = v0t and both v0 and t are unknown...
On the other hand, that acceleration for the moon doesn't really make sense either; free fall acceleration near the surface of the moon is approx. 1.6 m/s^2...
Too many hands.
Bailing out...
are you a teacher prudensoptimus?
No, I'm a freshman in high school. I'm going to be in 10th grade in beginning of August, so I want to prepare myself for the class.
s = 832 - 2.6t^2
and
s = 832 - 16t^2
I made a typo. Yes there are t's after 832s...
On the other hand, that acceleration for the moon doesn't really make sense either; free fall acceleration near the surface of the moon is approx. 1.6 m/s^2...B]
I think it makes sense. It takes longer for things to drop on the moon because the acceleration comparing to the Earth's gravity is smaller.
OK, then your answer is correct.
(and I just realized that the equations for question 1 are in feet/sec, not meters/sec, so the 2.6t^2 for the moon is OK too)
You know, you can make your work really easier (no need for calculus !).
s = 832t - 2.6t^2
s is displacement.
now, displacement will be equal to zero in only two cases (in projectiles) :
1-the object didn't move yet
2-the object went up and back down to the Earth's surface.
So all you have to do is to substitue the value of s with 0, and solve the equation :smile:.
And BTW, if i understood ur first way of solving this right, then i think there is something wrong about it. You see the velocity of the bullet will not be 0 when it reaches the surface, it will actually be equal in magnitude (and opposite in direction) of the initial velocity.
  • · Replies 38 ·
