Finding the equation of the tangent plane
  • Thread starter Thread starter grog
    Plane Tangent
The equation of the tangent plane to the surface defined by the equation xy + yz + zx = 3 at the point (1, 1, 1) is x + y + z = 3. The partial derivatives at this point are calculated as Fx(1, 1, 1) = 2, Fy(1, 1, 1) = 2, and Fz(1, 1, 1) = 2. Both approaches to finding the tangent plane yield consistent results, confirming the accuracy of the derived equation. The normal vector to the plane is represented by the vector i + j + k.
  • Understanding of multivariable calculus concepts, specifically tangent planes.
  • Familiarity with partial derivatives and their applications.
  • Knowledge of implicit functions and their derivatives.
  • Ability to manipulate equations in three-dimensional space.
  • Study the derivation of tangent planes for different surfaces in multivariable calculus.
  • Learn about implicit differentiation and its applications in finding derivatives of implicit functions.
  • Explore the geometric interpretation of normal vectors in relation to tangent planes.
  • Investigate the use of gradient vectors in determining the direction of steepest ascent on surfaces.
Students and educators in multivariable calculus, mathematicians interested in surface analysis, and anyone seeking to deepen their understanding of tangent planes and normal vectors in three-dimensional geometry.
grog
Find the equations of the tangent plane and the normal line to the given surface at the specified point.
xy+yz+zx=3 @ (1,1,1)
z-z0=fx(x0,y0)(x-x0) + fy(x0,y0)(y-y0)
I feel like this should be really easy, but I'm not sure how to get started. the equation from the book for the tangent plane seems to imply I should isolate z from the equation and go from there, but that seems like it would make things messy and more complicated than necessary.
ok, based on the solution to another problem, I've worked out:
F(x,y,z) = xy+yz+zx = 0
Fx = y+z = 2
Fy = x+z = 2
Fz = y+x = 2
and the equation of the plane as
2(x-1) + 2(y-1) + 2(z-1) = 0
or
x+y+z = 3
How does that look for the equation of the tangent plane?
Fx = y+z = 2
Fy = x+z = 2
Fz = y+x = 2
A correction to the above. The partials are all functions, and are not constant.
Fx(x, y, z) = y+z, Fx(1, 1, 1) = 2
Fy(x, y, z) = x+z, Fy(1, 1, 1) = 2
Fz(x, y, z) = y+x, Fz(1, 1, 1) = 2
or
x+y+z = 3
Looks fine to me.
I approached this a different way, assuming that z was (implicitly) a function of x and y.
From the original equation, I got
[tex]z_x = \frac{-y - z}{x + y}[/tex], and
[tex]z_y = \frac{-x - z}{x + y}[/tex]
At the point of tangency,
[tex]z_x(1, 1) = \frac{-y - z}{x + y}|_{(1, 1)} = -1[/tex], and
[tex]z_y(1, 1) = \frac{-x - z}{x + y}|_{(1, 1)} = -1[/tex]
From these I got the same equation for the plane, namely x + y + z = 3.
As a check, the point (1, 1, 1) satisfies the plane's equation.
The vector i + j + k is normal to the plane.
The two first partials, expressed as vectors are i - k [tex](z_x at (1, 1, 1))[/tex])
and j - k [tex](z_y at (1, 1, 1))[/tex]
If you dot the latter two vectors with the plane's normal vector, you get zero, meaning that the slopes of the partial derivatives are each perpendicular to the plane's normal. That pretty well nails down the plane.
  • · Replies 26 ·
