Average grain diameter at 310MPa from 2 known yield/grain values
  • Thread starter Thread starter physicsnnewbie
    Average Diameter
The discussion centers on determining the grain diameter at which the lower yield point of iron reaches 310MPa, given two known yield points at specific grain diameters. The lower yield point is 230MPa at a grain diameter of 1e-2mm and 275MPa at 6e-3mm. The Hall-Petch relationship is essential for solving this problem, as it describes the inverse relationship between grain size and yield strength. By applying this principle, one can calculate the required grain diameter for the specified yield point.
  • Understanding of the Hall-Petch relationship in materials science
  • Knowledge of yield strength and its dependence on grain size
  • Familiarity with basic equations in solid mechanics
  • Ability to perform calculations involving exponential relationships
  • Research the Hall-Petch equation and its applications in metallurgy
  • Learn how to derive yield strength from grain diameter using empirical data
  • Explore the effects of grain size on mechanical properties of metals
  • Investigate other factors influencing yield strength beyond grain size
Materials scientists, mechanical engineers, and students studying metallurgy who are interested in the relationship between grain size and yield strength in metals.
physicsnnewbie
The lower yield point for an iron that has an average grain diameter of 1e-2mm is 230MPa. At a grain diameter of 6e-3mm, the yield point increases to 275MPa. At what grain diameter will the lower yield point be 310MPa?
Not sure
Not sure how to do it.
Look up "Hall-Petch."
Thanks Mapes
28K
