Discover Patterns in Finite Series: Solving for n with 2008 Square Roots"
  • Thread starter Thread starter arpitm08
    Finite Series
The problem involves finding positive integers m and n such that n equals a nested square root expression with 2008 square roots. The original poster expresses uncertainty about how to proceed after rewriting the equation.
  • Participants discuss squaring both sides of the equation to eliminate square roots and consider the implications of forming a polynomial. There are attempts to simplify the nested structure and questions about the integer nature of the resulting expressions.
The discussion is ongoing, with participants exploring various interpretations of the problem and questioning the feasibility of certain assumptions about the integers involved. Some guidance has been offered regarding the nature of the expressions, but no consensus has been reached.
There is a focus on the integer constraints for m and n, and participants are questioning whether certain forms of the nested square root can yield integer solutions.
arpitm08
Are there positive integers m and n so that
n = sqrt(m+sqrt(m+sqrt(m+...sqrt(m))))
where there are 2008 square root signs.
2. The attempt at a solution
n^2=m+sqrt(m+sqrt(m+sqrt(m+...sqrt(m))))...with 2007 square roots.
Idk where to go from here. If there were infinite roots, then it would be a lot easier to do.
Any suggestions would be helpful. Thanks.
My first instinct is to get rid of ugly square roots. Square both sides and subtract m 2008 times to get a 2008th degree polynomial in m. You may be able to somehow write this as a binomial.
I don't see where that would get me tho.
((((n^2-m)^2-m)^2-m)^2...-m)^2-m=0
Where do i go from there. Its still as complicated as before.
How about this? If n=sqrt(m+a) with n and m integers, then a is an integer. That tells you that the expression with 2007 square roots is an integer. Etc. Etc. Eventually you get down to sqrt(m+sqrt(m)) is an integer. Is that possible?
I don't think its possible, b/c ur assuming that m and n are integers.
Can you show it's not possible? You are talking about k=sqrt(m+sqrt(m)), I assume.
So it would become:
((((a^2-m)^2-m)^2-m)^2...-m)^2=m
Are u saying that since a and m are integers, this expression would be an integer too, which would equal m??
No. I'm saying if n=sqrt(m+a) that means 'a' must be an integer. Where 'a' is the expression with 2007 square roots. Then the integer a=sqrt(m+b), where b is the expression with 2006 square roots. b must also be an integer so b=sqrt(m+c) where c is the expression with 2005 square roots. Etc etc. Eventually you get down to z=sqrt(m+sqrt(m)) is an integer. Is THAT possible?
YES! And then would you say that since sqrt(m+a) is an integer, there exists integers that satisfy this equation??
No, again. Because I don't think you can solve that final equation, z=sqrt(m+sqrt(m)) where z and m are integers. Try it.
Thank You Very Much! =)
9K
