Scissor Car Jack Purpose of Teeth
  • Thread starter Thread starter Altairs
    Car Teeth
The discussion centers on the purpose of the gear-like teeth in a scissor car jack, exploring their role in the mechanism's functionality and stability during operation. Participants examine whether the screw alone is sufficient for lifting and the implications of the absence of these teeth.
  • One participant questions the necessity of the teeth, suggesting that the screw might be sufficient for lifting the jack.
  • Another participant speculates that the teeth could serve as a safety feature to prevent failure of the worm drive system.
  • A participant explains that the teeth allow certain struts to move past one another while maintaining structural support.
  • Concerns are raised about the potential consequences if the teeth were absent, particularly regarding the stability of the struts during operation.
  • Another participant describes the construction of the jack, emphasizing that the absence of teeth would allow undesirable lateral movement due to the pin joints acting like a four-bar linkage.
  • It is noted that the teeth constrain the movement of the jack, ensuring that the bracket plate remains parallel to the base plate, which is crucial for stability under load.
Participants express differing views on the necessity and function of the teeth, with some supporting their importance for stability and others questioning their role. The discussion remains unresolved regarding the implications of their absence.
Some assumptions about the mechanical design and load conditions are not fully explored, and the discussion does not resolve the specific mechanical advantages provided by the teeth versus the screw alone.
Altairs
What is the purpose of teeth in such jack ? Isn't the screw enough to provide the lift ? What will happen if these gear like teeth are not present in a scissor jack ?
I'm not sure what you mean by 'teeth', since I've never seen such a thing. My best guess without a visual aid is that it might be some kind of safety catch in case of the worm drive system stripping out.
Can you post a picture?
Check the attachment...Number 19 is what I was referring to...
Moderator Note: In future, please resize your images to a maximum of 800 x 600 pixels.
Those teeth allow struts 12&14 and struts 13&15 to move past one another while remainng in in contact in such a way as to structurally support each other.
And if these aren't there then what change will come to these struts while e.g. ascending and descending the car?
Look at the construction at the bottom of the jack. There are actually to adjacent pivots, not a single pivot.
Now imagine for a moment that the gear teeth are not there. The base plate, the two lower arms, and the screw are all connected by pin joints, so they act like a four bar linkage and can move laterally. This would be highly undesirable for the jack! The purpose for the gear teeth is to remove this degree of freedom and prevent the lateral motion of the jack.
Altairs: The scissor jack teeth (item 19) constrain both sides of the jack to rise or descend exactly the same amount, thus forcing bracket plate 16 to remain parallel to base plate 11 (and therefore parallel to the ground surface). If the teeth were not present, bracket plate 16 could rotate in response to grossly eccentric loading applied to plate 16. And, if bracket plate 16 (and base plate 11) were free to rotate, then the entire jack could translate/rotate laterally about base plate 11, as pointed out by Dr.D.
14K
