Find Value of Line Integral Homework - E.dl, P Circular Path Centered on Origin
The discussion centers on calculating the line integral of the magnetic field B around a circular path P in a time-varying electric field E = E0sin(kz + wt + π/3) k. The correct formulation for the line integral is given by the equation ∫ B.dl = +ε0μ0(dΦ_E/dt), which relates the magnetic field to the rate of change of electric flux through the loop. The initial misunderstanding was regarding the nature of the electric field, which is not constant but varies with time.
  • Understanding of Maxwell's equations, specifically Faraday's law of induction.
  • Familiarity with line integrals in vector calculus.
  • Knowledge of electric and magnetic fields in electromagnetism.
  • Basic concepts of electric flux and its relation to magnetic fields.
  • Study Faraday's law of electromagnetic induction in detail.
  • Learn about the relationship between electric fields and magnetic fields in dynamic systems.
  • Explore the concept of electric flux and its mathematical representation.
  • Practice solving line integrals in the context of electromagnetism.
Students in physics or engineering disciplines, particularly those focusing on electromagnetism, as well as educators looking for examples of line integrals in practical applications.
lovinuz
There is a constant electric field E = E0sin(kz+wt+pi/3) k(direction vector). What is the value of the line integral(P) B.dl, where P is a circular path, centered on the origin, lying in the xy-plane, having radius r?
integral E.dl = -dI/dt
I am having difficulty approaching this question, can someone please give me some kind of push? Thanks.
First, that isn't a constant electric field. It varies with time.
Second, your equation in (2) should read:
[tex]\int B.dl = +\epsilon_0 \mu_0 \frac{d\Phi_E}{dt}[/tex]
so that the line integral of the magnetic field B around the circle relates to the change in electric flux passing through the loop.
The equation you quoted looked like it was for the line integral of the electric field around a closed loop.
Can you see where to go from here?
  • · Replies 58 ·
  • · Replies 19 ·
  • · Replies 35 ·
