Solving Geodesic Equations on Surfaces of Revolution
  • Thread starter Thread starter mooshasta
    Geodesic
The discussion focuses on solving geodesic equations on surfaces of revolution, specifically using the parametrization \(\psi(t, \theta) = (x(t), y(t) \cos \theta, y(t) \sin \theta)\) where \(\alpha(t) = (x(t), y(t))\) is a unit speed curve. The equations governing the geodesic are \(\ddot{\theta} = -2 \frac{y'}{y} \dot{\theta} \dot{t}\) and \(\ddot{t} = y y' \dot{\theta}^2\). The goal is to demonstrate that \(\dot{t}^2 + y^2 \dot{\theta}^2 = E\) and \(y^2 \dot{\theta} = A\) are independent of \(s\). The discussion highlights the importance of differentiating the equations with respect to \(s\) and recognizing the relationship \(\frac{dy}{ds} = y' \dot{t}\).
  • Understanding of geodesic equations in differential geometry
  • Familiarity with parametrization of surfaces of revolution
  • Knowledge of calculus, particularly differentiation with respect to a parameter
  • Concept of unit speed curves and their properties
  • Study the derivation of geodesic equations on surfaces of revolution
  • Learn about the implications of unit speed curves in differential geometry
  • Explore the method of differentiating equations with respect to parameters
  • Investigate the physical interpretations of conserved quantities in geodesics
Mathematicians, physicists, and students studying differential geometry, particularly those interested in geodesics and surfaces of revolution.
mooshasta
I'm given the surface of revolution parametrized by [itex]\psi (t, \theta ) = (x(t), y(t)cos \theta, y(t)sin \theta )[/itex] where the curve [itex]\alpha (t) = (x(t),y(t))[/itex] has unit speed. Also given is that [itex]\gamma (s) = \psi (t(s), \theta (s))[/itex] is a geodesic which implies the following equations hold:
[tex] \ddot{\theta} = -2 \frac{y'}{y} \dot{\theta} \dot{t}[/tex] and [tex]\ddot{t} = y y' \dot{\theta}^2[/tex]
where
[tex] y' = \frac{dy}{dt}, \dot{\theta} = \frac{d \theta}{ds}, \ddot{\theta} = \frac{d^2 \theta}{ds^2}, \dot{t} = \frac{dt}{ds}, \ddot{t} = \frac{d^2 t}{ds^2}[/tex]
I have to show that the following quantities are independent of [itex]s[/itex]:
[tex]\dot{t}^2 + y^2 \dot{\theta}^2 = E[/tex]
[tex]y^2 \dot{\theta} = A[/tex]
All that I can think may be of relevance that isn't already listed is that for a unit speed curve, [tex]y'^2 + x'^2 = 1[/tex]. Not sure that this matters here, though.
I've tried rearranging the equations to try to resemble the desired equations, but it's been pretty unfruitful. I was thinking about maybe differentiating one of the equations w.r.t. [itex]s[/itex], but I'm not sure how one would deal with the third derivative of [itex]t[/itex] or [itex]\theta[/itex].
Any help (or hints) are is appreciated! Thanks!
In this case, I think the easiest way to tackle this is to work backwards from the two equations you are trying to prove:
What is [tex]\frac{d}{ds}(y^2 \dot{\theta})[/tex]?:wink:
Thank you! Your hint was just what I needed. For some reason I was forgetting that [itex]\frac{dy}{ds} = y' \dot{t}[/itex], but now it makes perfect sense.
Thanks again :)
