Projectiles launched at an angle
  • Thread starter Thread starter aly1201
    Angle Projectiles
The problem involves determining the minimum speed of a baseball hit at an angle to clear a fence of a specified height and distance from the point of launch. The context includes projectile motion and the application of kinematic equations.
  • Exploratory, Mathematical reasoning, Problem interpretation
  • Participants discuss the use of kinematic equations to relate the horizontal and vertical components of the baseball's motion. There are attempts to isolate variables and clarify the role of time in the equations. Questions arise about the correct setup of the equations and the interpretation of the variables involved.
The discussion is active, with participants providing guidance on how to manipulate the equations to isolate the variable of interest. There is a collaborative effort to clarify misunderstandings regarding the equations and the relationships between the components of motion.
Participants note potential confusion regarding the inclusion of time in the equations and the implications of using trigonometric identities. There is an acknowledgment of the need for careful algebraic manipulation to solve for the desired variable.
aly1201
A baseball is hit over a 7.5-m-high fence 95 m from the home plate. What was the minimum speed of the ball when it left the bat? Assume the ball was hit 1 m above the ground and its path initially made a 38 degree angle with the ground.
y=v(initial, y direction)t-1/2at^2 x=v(initial, x direction)t
t=95/v 95/v(cos38) ? plug 95/v(cos38) into the y equation? and substitute v(sin38) for initial y velocity? This is where I get lost; our teacher wrote all the work on the board very quickly and came up with an answer somehow, but when I did the work I didnt even come close.
You have the following (correct) equation for the height of the ball right when it gets to the fence:
[tex]y=v\sin(38^o)-\frac{1}{2}g\left(\frac{95}{v\cos(38^o)}\right)^2[/tex]
Now how high do you want the ball to be so that it just barely the fence? Plug that in for y and when you solve for v, you'll get the minimum speed.
Ok but I don't understand how to get v by itself, with the cos38 and sin38 there. And in the equation you wrote is "t" supposed to be in there at all?
There is a t missing in the vsin(38) term in that equation. G01 has substituted for t since you can express it in terms of the horizontal distance and horizontal velocity. As already pointed out, you can figure out what y should be from the information given in the problem. So the equation should look like this:
[tex]y=v\sin(38^o)\left(\frac{95}{vcos(38^o)}\right)-\frac{1}{2}g\left(\frac{95}{v\cos(38^o)}\right)^2[/tex]
Now it is just algebra. To isolate v, start by getting the term containing v on its own on one side of the equation (note the v's cancel in the first term!)
Ok so [95/v(cos38)]^2=[6.5-(tan38)(95)]/-4.9? because sinX/cosX=tanX
Looks good so far. What would you do next?
I solved the right side and got 13.8, which i took the square root of (since the left side was squared) and got 3.7. Then I divided that by 95 and got 25.6. So now v(cos38)=25.6? If it does then I could just say 25.6/cos38=v, so 25.6/.79=32.4?
I might've rounded too much so it might not be exact, and I am not sure if you can have cosX or sinX by itself?
That answer looks OK to me.
It was thank you! I appreciate the help!
  • · Replies 38 ·
