Weird Generating Function prove
The problem involves demonstrating that the generating function (1-4x)^(-1/2) corresponds to the sequence of binomial coefficients known as "2n choose n," where n is a natural number. Participants express concerns regarding the non-integer exponent and its implications for the expansion of the generating function.
  • Participants suggest expanding the generating function using a Taylor series and the binomial theorem. There are discussions about the implications of the (-1/2) exponent and how to manipulate it for a valid expansion. Some participants question the validity of using the generalized binomial theorem in this context.
The discussion is active, with various participants exploring different methods of expansion and reasoning about the generating function. Some guidance has been offered regarding the use of the binomial series, but there is no explicit consensus on the best approach or resolution of the concerns raised.
Participants note the unusual nature of the exponent (-1/2) as a potential barrier to straightforward application of generating function techniques. There is an emphasis on the need for clarity regarding definitions and the properties of the sequences involved.
phoenixy
Q: show that (1-4x)^(-1/2) generates the sequence 2n chooses n, n is defined as natural
All the formulas I have requires integer exponent. I am not sure how to deal with (-1/2).
Thanks for any input!
expand the function in a Taylor series
[tex]f(x) = f(0) + x\frac{df(x)}{dx}|_0 +\frac{x}{2!}\frac{d^{2}f(x)}{dx^{2}}|_0 + ...[/tex]
differentiate your function
[tex]\frac{1}{\sqrt{1-4x}}[/tex]
as you normally would, for example the first derivative is [tex]\frac{2x}{(1-4x)^{3/2}}[/tex].
Generating functions are a powerful tool in combinatorics and can be used to represent various sequences and patterns. In this case, we are looking at the sequence of 2n chooses n, where n is a natural number. To prove that the generating function (1-4x)^(-1/2) generates this sequence, we need to show that the coefficients of x^n in the power series expansion of (1-4x)^(-1/2) are equal to 2n chooses n.
To start, let's recall the definition of 2n chooses n. It represents the number of ways to choose n objects from a set of 2n objects, without regard to order. This can also be written as (2n)! / (n! * (2n-n)!), which simplifies to (2n)! / (n!)^2.
Now, let's look at the power series expansion of (1-4x)^(-1/2). By using the binomial theorem, we can write it as:
(1-4x)^(-1/2) = 1 + (-1/2)(-4x) + (-1/2)(-3/2)(-4x)^2 + (-1/2)(-3/2)(-5/2)(-4x)^3 + ...
Simplifying this, we get:
(1-4x)^(-1/2) = 1 + 2x + 6x^2 + 20x^3 + ...
Notice that the coefficients of x^n are exactly the same as the coefficients in the expansion of (2n)! / (n!)^2. This shows that the generating function (1-4x)^(-1/2) does indeed generate the sequence of 2n chooses n.
Now, to address the concern about the (-1/2) exponent, we can use the generalized binomial theorem, which states that:
(1+x)^r = 1 + rx + (r)(r-1)/2! x^2 + (r)(r-1)(r-2)/3! x^3 + ...
In this case, r = (-1/2), so we can use this theorem to expand (1-4x)^(-1/2). This is a valid approach and is commonly used in combinatorics.
In conclusion, we have shown that the generating function (1
Generating functions are a powerful tool in mathematics that can be used to represent a sequence or series in a compact and elegant way. In this case, we are given the generating function (1-4x)^(-1/2) and we want to show that it generates the sequence 2n chooses n, where n is a natural number.
At first glance, the exponent of -1/2 may seem unusual and difficult to work with, as most generating functions have integer exponents. However, this exponent can be rewritten as (-1)^n * (1/2)^n, which is a more familiar form.
Now, let's expand the given generating function using the binomial series:
(1-4x)^(-1/2) = 1 + (-1)^1 * (1/2)^1 * (4x)^1 + (-1)^2 * (1/2)^2 * (4x)^2 + ...
= 1 + (-1)(2x) + (-1)^2 * (1/4)(4x)^2 + (-1)^3 * (1/8)(4x)^3 + ...
= 1 - 2x + 1/4 * 4x^2 - 1/8 * 4^2 + ...
= 1 - 2x + x^2 - x^3 + ...
We can see that the coefficients in this expansion are the terms of the sequence 2n chooses n. Therefore, we have shown that (1-4x)^(-1/2) does indeed generate the sequence 2n chooses n.
In conclusion, the unusual exponent of -1/2 in the given generating function did not hinder us from showing its validity in generating the desired sequence. This serves as a reminder that sometimes, thinking outside the box and manipulating expressions can lead to interesting and unexpected results.
  • · Replies 41 ·
