Can You Solve These Challenging USAMO Qualifier Questions?
  • Context: Graduate
  • Thread starter Thread starter killerinstinct
The discussion revolves around solving two challenging problems from the USAMO qualifier. The first problem involves calculating the probability of winning a board game after a series of moves, while the second problem requires solving a logarithmic equation to find a specific value of 'a'. The scope includes mathematical reasoning and problem-solving strategies.
  • Some participants propose that the probability of winning the board game after seven moves is represented as p, leading to the calculation of 4096p.
  • One participant claims to have found p = 819/4096 for the first question.
  • Another participant expresses difficulty in solving the second question without numerical approximations, ultimately arriving at a value of a ≈ 4.217.
  • Several participants discuss the logarithmic properties and transformations involved in the second question, with one providing a detailed step-by-step solution that concludes with a^3 = 75.
  • Some participants note the importance of understanding why the problem asks for 4096p rather than p directly, suggesting it may indicate a deeper insight into the problem's structure.
  • There is a mention of different approaches to the second question, with one participant outlining a method involving logarithmic manipulation to derive the final result.
Participants generally express differing levels of confidence and methods in solving the problems, with no consensus on the best approach or final answers for both questions. Multiple competing views on the second question's solution exist, and some participants express frustration with the complexity of the problems.
Some participants rely on numerical approximations and calculators, while others prefer algebraic manipulation. There are unresolved steps in the mathematical reasoning, particularly in the transition from logarithmic forms to numerical solutions.
Mathematics enthusiasts, students preparing for math competitions, and individuals interested in problem-solving techniques may find this discussion beneficial.
killerinstinct
:surprise: Suppose we are playing a board game with the following rules:
1. The board has 5 spaces on it.
2. Your playing piece starts out on space number 1.
3. Each move consists of moving the piece to a randomly chosen space other than the one which you currently occupy (for example, if you are on space number 2, you randomly move to either space 1, 3, 4, or 5, with each space having equal chance of being selected, but you cannot stay on space number 2).
4. You win if, after seven moves, you are back on space 1.
The probability of winning this game is p. Find 4096p.
:eek: Suppose log.4a (40*sqrt(3)) = log.3a (45)
(Log.m (n) denotes log base m of n. sqrt(x) denotes the square root of x.)
Find a^3 (a^3 denotes "a cubed.")
a^3 = 75.
Will work on Q1 now...
hmmmm... 4096 = 2^12 = (2^2)^6 = 4^6 = (5-1)^(7-1)
interesting question.
Ehm, 4096 = 2^12.
For the second question, consider rewriting both logs with the same base.
Answer to Q1 is p=819/4096
You know I had no problem with Q1. But in Q2 I couldn't do it without pluging in numbers and doing what parts I could do on a calculator (windows calc). So instead of getting a=75^(1/3) as Gokul did I just got whole bunch of messy numerical intermediates before getting a final answer of a=4.21716332650874621422854875703.
Actually what I had was :
a = 10^(log(k)/(m-1))
where m= log.45(40r3) and k=4/(3^m) were the numerical intermediates.
I still can't figure why it comes out to 75^(1/3), does this mean I'd fail the test :cry:
Muzza said:
Ehm, 4096 = 2^12.
You do realize you were asked to find 4096p, in other words find p (the probability of winning the game)?
Yes, but thanks for clarifying (we're not morons)... hello3719 originally wrote 4096 = 2^14 (but has since edited his post), and I thought I'd correct it.
In some contests you don't always have time to solve the problem completely so you must use some shortcuts. I didn't claim I've solved the problem only getting the feel of it by wondering why they want us to find 4096p and not EXPLICTLY p. Everyone knows how to multiply by 4096 when they get p, but sometimes that isn't the goal of the problem.
why it is 75
Hmm... #2 is fairly simple. I'll write my solution as a good LaTeX practice...
[tex]\log_{4a}40\sqrt3 = \log_{3a}45[/tex]
[tex]\frac{\log40\sqrt3}{\log4a} = \frac{\log45}{\log3a}[/tex]
[tex]\frac{\log40\sqrt3}{\log45} = \frac{\log4a}{\log3a}[/tex]
[tex]\log_{45}{40\sqrt3} = \log_{3a}{4a}[/tex]
[tex](3a)^{\log_{45}{40\sqrt3}} = 4a[/tex]
[tex](3a)^{\log_{45}{40\sqrt3}-1} = \frac{4}{3}[/tex]
[tex]a^3 = (\frac{4}{3^{\log_{45}{40\sqrt3}}})^{ \frac{3}{\log_{45}{40\sqrt3} - 1}[/tex]
after obvious modification i am too lazy to type up
[tex]y = \log_{45}{40\sqrt3} - 1[/tex]
[tex]a^3 = (\frac{4}{3})^{\frac{3}{y}}(1/27)[/tex]
here is the annoying part
[tex]y = \log_{45}{40\sqrt3} - 1 = \log_{45}{(40/45)\sqrt3}[/tex]
[tex]= \log_{45}{(8/9)\sqrt3} = \log_{45}{4^{3/2}/3^{3/2}}[/tex]
[tex]= 3/2 \log_{45}{4/3}[/tex]
then magically,
[tex]a^3 = (\frac{4}{3})^{\frac{3}{3/2 \log_{45}{4/3}}}(1/27)[/tex]
[tex]= (\frac{4}{3})^{2\log_{4/3}{45}}(1/27)[/tex]
[tex]= 45^2(1/27) = 81\times25\times\frac{1}{27} = 75[/tex]
Whoopdeedoo.
I hate this question.
Contests are a waste of time.
Thanks for the details AmirSafavi. I went through the first three steps much the same as yourself, but once I had one side of the equation purely numerical it was just too irresistable for me to finish it using floating point approx.
I'd say that about takes care of these 2 questions. lol!
Here's another way to solve Q2.
Let log.4a (40*sqrt(3)) = x = log.3a (45)
Then, (4a)^x = 40*sqrt(3) and (3a)^x = 45. Now take logs on both sides...
So, x*log(4a) = log(40*sqrt(3)) and x*log(3a) = log(45). Subtract one of these equations from the other...
You get, x*log(4/3) = log(40*sqrt(3)/45). But 40*sqrt(3)/45 = 8*sqrt(3)/9 = (4*sqrt(4)/3*sqrt(3) = (4/3)^1.5
So x = 1.5 , plug this into (4a)^x = 40*sqrt(3) to get 8*a^1.5 = 40*sqrt(3) or a^1.5 = 5*sqrt(3)
Hence a^3 = 25*3 = 75
Simple, wot ?
That explanation hurts my eyes, but after reading it, that is a more simpler way of solving this problem.
  • · Replies 66 ·
