How Do You Solve a Double Integral for Area Between z=e^{x^2} and the xy-Plane?
The problem involves finding the area between the xy-plane and the surface defined by z = e^{x^2}, bounded by the lines x = 0, x = 1, and y = 2x. The context is within the subject area of double integrals in calculus.
  • Participants discuss setting up the double integral for the area, with some suggesting the order of integration and others emphasizing the importance of understanding the geometric region defined by the boundaries.
There is an ongoing exploration of different approaches to setting up and evaluating the double integral. Some participants provide insights into the setup and integration process, while others raise questions about the interpretation of the problem and the boundaries involved.
Participants note the significance of visualizing the region in the xy-plane and the need to clarify the relationship between the surface and the xy-plane. There is also mention of the importance of understanding the limits of integration based on the given boundaries.
tandoorichicken
I was just faced with this problem on a test and I have no idea how to do it Find the area between the xy-plane and [itex]z= e^{x^2}[/itex] as bounded by x=0, x=1, and y=2x.
I have no idea how to do this problem. I set up the integral as
[tex]\int_{0}^{1} \int_{0}^{2x} e^{x^2} \,dy \,dx[/tex]
What is the problem here?
Do the y-integration, and then the x-integration.
First, it's important to note that the xy-plane is the plane where z=0. So, we are essentially finding the area between the x-y plane and the curve z=e^{x^2}.
To solve this problem, we can use the concept of double integrals, where we integrate over two variables (in this case, x and y) to find the area between the two curves.
To set up the integral, we start by integrating with respect to y first, since that is the inner integral. The limits of integration for y are from 0 to 2x, as given in the problem.
Next, we integrate with respect to x, with limits of integration from 0 to 1.
So, our integral becomes:
To solve this, we can use the fundamental theorem of calculus, which states that the integral of a function over a specific interval is equal to the difference of the antiderivatives evaluated at the endpoints of the interval.
In this case, the antiderivative of e^{x^2} is \frac{1}{2}e^{x^2}, so our integral becomes:
\int_{0}^{1} \frac{1}{2}e^{x^2} \,dx
Evaluating this at the endpoints, we get:
\frac{1}{2}e^{1^2} - \frac{1}{2}e^{0^2}
= \frac{1}{2}e - \frac{1}{2}
= \frac{1}{2}(e-1)
So, the area between the xy-plane and z=e^{x^2} bounded by x=0, x=1, and y=2x is \frac{1}{2}(e-1).
It's important to note that this is just one approach to solving this problem. There may be other methods or techniques that can also be used. It's always a good idea to practice different approaches and see which one works best for you.
First, it's important to understand what the problem is asking for. In this case, we are finding the area between the xy-plane (z=0) and the function z=e^{x^2}, bounded by the lines x=0, x=1, and y=2x. This means we are looking for the region in the xy-plane where z=0 and z=e^{x^2} intersect, and the boundaries of this region are given by the lines x=0, x=1, and y=2x.
To solve this double integral, we can follow these steps:
1. Draw the region in the xy-plane: Before setting up the integral, it's helpful to visualize the region we are looking for. In this case, it is a triangular region bounded by the lines x=0, x=1, and y=2x. Draw this region on a graph to get a better understanding of the problem.
2. Set up the integral: As you have correctly done, the double integral is set up as \int_{0}^{1} \int_{0}^{2x} e^{x^2} \,dy \,dx. This represents the area under the surface z=e^{x^2} within the given boundaries.
3. Evaluate the inner integral: The inner integral, \int_{0}^{2x} e^{x^2} \,dy, represents the area under the curve e^{x^2} within the boundaries of y=0 and y=2x. This can be solved by simply integrating e^{x^2} with respect to y, giving us e^{x^2}y evaluated from y=0 to y=2x. This simplifies to 2xe^{x^2}.
4. Evaluate the outer integral: The outer integral, \int_{0}^{1} 2xe^{x^2} \,dx, represents the total area of the region bounded by x=0, x=1, and y=2x. This can be solved by integrating 2xe^{x^2} with respect to x, giving us e^{x^2} evaluated from x=0 to x=1. This simplifies to e-1.
5. Final answer: The final answer is e-1, which represents the area between the xy-plane and z=e^{x^2} as bounded by
  • · Replies 25 ·
