The discussion revolves around the compatibility of an Orion solar filter designed for the Observer 60 Altaz & EQ model with a Celestron 60 AZ Model telescope. Participants explore the fit based on specifications and measurements, considering both the manufacturer's guidance and personal experiences.
- Exploratory, Technical explanation, Debate/contested
- One participant expresses interest in using an Orion solar filter for their Celestron 60 AZ Model, noting that the compatibility guide only lists Orion models.
- Another participant asserts that if Orion indicates it will fit, then it should fit, suggesting confidence in the manufacturer's claim.
- A clarification is made that the guide specifically mentions compatibility with Orion's 60mm AZ model, not Celestron models, leading to uncertainty about the fit.
- One participant proposes that since both telescopes have a 60mm aperture, the filter might work, but suggests verifying with Orion for precise measurements to ensure compatibility.
Participants express differing levels of confidence regarding the compatibility of the solar filter with the Celestron model. Some believe it will fit based on aperture size, while others emphasize the need for confirmation from the manufacturer.
There is a reliance on the manufacturer's compatibility guide, which does not include Celestron models, creating uncertainty. The discussion also highlights the importance of precise measurements for compatibility.
Telescope owners considering solar filters, particularly those with Celestron or Orion models, may find this discussion relevant.
