Sending signals through the computer?
  • Thread starter Thread starter pooface
    Computer Signals
The discussion revolves around a project aimed at creating a Smith Chart calculator/simulator that retrieves the characteristic impedance (Zo) and load impedance (ZL) from a real transmission line using a computer interface. Participants explore the feasibility of using USB to coax adapters and the necessary electronics to analyze signal reflections and pulses.
  • Homework-related
  • One participant outlines a project to calculate various transmission line parameters and seeks guidance on connecting a coax cable to a computer via USB.
  • Another participant questions the use of USB for this purpose, suggesting that a microcontroller and a USB/RS-232 adapter might be more suitable for sending and receiving pulses.
  • Concerns are raised about the computer's ability to interpret pulses correctly, noting that the resolution may be poor.
  • A suggestion is made to use specific devices for detecting pulse arrival times and to consider voltage and time resolution requirements.
  • Participants discuss the need for a calibrated driver and a fast oscilloscope-type digitizer to monitor reflections and initial amplitudes for accurate measurements.
  • One participant mentions the possibility of simulating data based on transmission line equations as an intermediate step if hardware is not available.
  • Another participant expresses uncertainty about the effectiveness of the suggested adapters for the intended purpose and considers alternative methods using available lab equipment.
Participants do not reach a consensus on the best approach to connect the coax cable to the computer or the effectiveness of the proposed adapters. Multiple competing views on the necessary equipment and methods remain present throughout the discussion.
Some participants highlight limitations regarding the cost of data acquisition hardware and the need for specific software to analyze pulse data. There is also uncertainty about how to accurately determine ZL based on existing databases of transmission lines.
Individuals interested in transmission line theory, signal processing, and practical applications of impedance measurement may find this discussion relevant.
pooface
Hello there,
My project is a Smith Chart calculator/simulator that takes the Zo and ZL of a transmission line and calculates various data like SWR, SWR(dB), return loss, coeff I, E, P, etc. It also constructs and plots on a graphical Smith Chart.
I want to take this one step further and retrieve my Zo and ZL from a REAL transmission line.
I want to connect a coax cable via an usb to coax adapter and send a signal through my computer to determine these properties.
I need some ideas/guidance on this. Should I do this via the USB port? I think essentially I need to make a TDR to retrieve data such as E incident and E reflected.
It would be ok if I am not able to determine Zo for now and just use a data sheet. But I would like to retrieve data to calculate ZL and then send that data to my program.
Thanks so much in advance for your help!
pooface said:
Hello there,
What is your operating system? What kind of adapter is it? I have never used USB for such purpose and with other projects almost always used an USB / RS - 232 adapter. Then using typically a microcontroller for sending and receiving pulses. Immediate thought that comes to mind (I could be wrong) is, that you need some kind of specific software to show the received pulse unless you know something really handy in the OS API. All that I've seen just show data as bytes (8 bits = 8 pulses) and single pulses go to the abyss. This is an interesting project so please feel free to post on your progress.
Additionally computer interprets pulses as logical 1 or 0 so tdr pulse has to exceed the threshold to be interpreted as 1. Thinking more on this the resolution is quite poor.
Hi misgfool,
Thanks for your input.
OS: Win XP
Adapters:
http://www.twindata.com/forvus/3270coax-usb.htm
http://www.audiophileproducts.com/usbtospdif
I haven't purchased these, just kept them in my bookmarks to investigate what is a good way to go about this project.
I'm trying to collect information on how exactly I would analyze the pulses. As you mentioned, some piece of software that does that would be handy. I'll update this page as I make progress.
Thanks again.
There is a little more to it than this.
You need some electronics to detect the arrival time of a pulse.
What voltage? What time resolution?
You could start with something like this http://www.picotech.com/ reading the values from the device with the supplied library is fairly easy.
The devices you linked to are for sending digital comunications streams over coax.
pooface said:
Hi misgfool,
OS: Win XP
Adapters:
Thanks again.
I'm not understanding how those adapters are going to help you, but I could just be missing what you intend.
That's an ambitious extension to your project, but a very real-world extension, so that's a good thing. Yes, you would basically be making the TDR function of a cable tester, where you drive a fast-rise-time pulse from a known Zo driver down the coax, and monitor for the initial amplitude (for the cable Zo value), and for any reflections that come back (from cable mismatches, or from the wavefront hitting the termination if it is not matched).
To do this, you would need a driver with a calibrated Zo, and a fairly fast oscilloscope-type digitizer. You might be able to implement these with USB digital-output and USB analog-input modules, if you find ones with speed specs that look good. I'd look at National Instruments website to see generally what is available:
http://www.ni.com/dataacquisition/usb/
They are not the cheapest source around, but their quality is generally good, and we buy a lot of stuff from them for our own test equipment needs.
Now, a less expensive alternative would be to generate some data to simulate what you would get from your DAQ card, if you really had built the whole thing up. Generate the data based on the equations for TLs, and then feed that data back into your Smith chart mapping software. That would be a good intermediate step.
Alternately, you can make your TDR up out of a signal generator and digital oscilloscope, capture the 'scope data, and feed that into your program. That would be cool, and doesn't cost you the $ of the USB data acq hardware.
Many thanks Mgb_phys and berkeman for your responses!
I was thinking with those adapters I linked to, that I would send a pulse and retrieve reflected data and then analyze that data via some software but that doesn't seem to be a good approach.
I looked at the lowcost DAQ products at NI you linked me to and yes 220 dollars CDN is a lot of money for a school project.
I'm not clear on the second suggestion you gave. Would I have a database of TLs lines(for Zo) then use the length and equations to figure out ZL?
The third suggestion is a route I'm most likely going to take. In my college we have labs with Labjacks(DAQ units but I think they are serial) and Agilent scopes and generators with the Agilent VEE software on the computers at the stations. We also have HCS12s, I will ask my prof what else he has.
Many thanks for direction on my project!
I might be cheaper, but the cool-o-meter would definitely be plummeting.
