Equation about polynomials that implies polynomials are zero
  • Thread starter Thread starter mohlam12
    Polynomials Zero
The discussion revolves around a problem involving real polynomials P, Q, and R, specifically examining the implication of the equation P² = X(Q² + R²) leading to the conclusion that P = Q = R = 0. Participants are exploring alternative methods to demonstrate this relationship without relying on degree arguments.
  • Participants are questioning the definition of the variable X and the implications of the original statement regarding the polynomials. There is a suggestion to demonstrate that constant coefficients are equal to zero. Others are exploring the validity of the assumption that P, Q, and R must have the same degree.
The discussion is active, with participants clarifying the original problem statement and exploring various interpretations. Some guidance has been offered regarding the degree of the polynomials, and there is acknowledgment of a potential logical mistake in the initial formulation of the problem.
There is a noted confusion regarding the initial problem statement and the assumptions about the degrees of the polynomials involved. Participants are also considering the implications of the non-negativity of the square of a polynomial.
mohlam12
Hi everyone,
I have to demonsrate that for every real polynomial, P Q and R, I have :
P²=X(Q²+R²) ==imply==> P=Q=R=0
Using degrees, we can easily demonsrate the above. However, I'm looking for another way, without using that.
What is X? :confused:
X is the variable ! We can rewrite the problem this way :
if P(X), Q(X) and R(X) belongs to R[X], then writing P²(X) = X(Q²(X) + R²(X)) means P(X)=Q(X)=R(X)=0
Someone adviced me to start with demonstrating that constant coefficients are equal to 0 ? :s
The problem still makes no sense. Surely you don't mean "for every real polynomial, P Q and R" and then say "P= Q= R= 0".
Suppose Q= R= x and P= 2x3. Does that contradict what you are trying to prove? Are you assuming that P, Q, and R are have the same degree?
My bad ! Here's the exact question :
"Demonstrate that if P, Q, and R belong to R[X], therefore P² - XQ² = XR² imply that P=Q=R=0"
Big logic mistake in my first post -.- sorry
I think the "degree argument" you mentioned is still the simplest and best way to go. If n is the higher degree of Q and R, then the degree of xQ2+ R2 is 2n+ 1 so the degree of P would have to be (2n+1)/2, not an integer.
At the risk of pointing out the obvious, [itex]f(x)^2 \geq 0[/itex] for every real x...
  • · Replies 24 ·
