Velocity as function of Displacement to Displacement as function of Time
The discussion revolves around the conversion of a velocity function defined in terms of displacement into a displacement function defined in terms of time. Participants explore the implications of non-constant acceleration and the application of calculus techniques to achieve this transformation.
  • Exploratory, Technical explanation, Mathematical reasoning
  • One participant presents a velocity function V(x) = 0.0002x^2 - 0.6484x + 885 and seeks assistance in deriving displacement as a function of time.
  • Another participant identifies the relationship between velocity and displacement as a differential equation dx/dt = 0.0002x^2 - 0.6484x + 885 and suggests rewriting it for integration.
  • A question is raised regarding a potential error in notation, specifically whether "dv" should actually be "dx" in the context of the differential equation.
  • A subsequent reply confirms that the notation should indeed be corrected to "dx."
Participants do not reach a consensus on the correct formulation of the differential equation, as a notation error is identified but not resolved in terms of its implications for the overall problem.
The discussion highlights the challenge of dealing with non-constant acceleration and the need for careful application of calculus techniques, particularly in the context of integrating differential equations.
This discussion may be of interest to those studying calculus, particularly in relation to motion and dynamics, as well as individuals seeking to understand the conversion between different mathematical representations of motion.
StephenSF8
I've measured velocities of a particle at varying displacements and characterized the velocity as [tex]V(x) = 0.0002x^2 - 0.6484x + 885[/tex].
You can see that I know velocity (V) as a function of displacement (x). Ultimately I want to end up with a function for displacement as a function of time (t). I imagine that somehow a chain rule is used to change the variables, but I'm having trouble figuring it out. The books I have glaze over the issue of non-constant acceleration...
Will somebody with more calculus experience help me out? Thanks.
Oh, and the initial conditions are x = 0, and so V(0) = 885.
Since v= dx/dt you have, effectively, the differential equation [itex]dx/dt= 0.0002x^2 - 0.6484x + 885[/itex] which you can rewrite
[tex]\frac{dv}{0.0002x^2 - 0.6484x + 885}= dt[/itex]<br /> Factor the denominator and use "partial fractions" to integrate.[/tex]
Shouldn't that "dv" in the last term be a "dx" ?
yes.
  • · Replies 49 ·
  • · Replies 23 ·
  • · Replies 27 ·
