Deriving Capacitor Reactance: AC Signals & Ohm's Law
  • Thread starter Thread starter unseensoul
    Reactance
The discussion centers on deriving the opposition to current flow (reactance) in capacitors when subjected to AC signals, specifically without using complex numbers. Participants explore the nature of capacitor reactance, its constancy, and the application of Ohm's Law in AC circuits.
  • Some participants inquire about deriving capacitor reactance without complex numbers and question whether reactance is a constant or an average.
  • It is proposed that reactance can be calculated using the formula Xc = 1/(2πfC) under the assumption of a lossless capacitor.
  • Some participants express uncertainty about measuring instantaneous voltage and current to derive reactance, suggesting that Ohm's Law may not apply directly in AC circuits due to phase differences.
  • There is a discussion about whether reactance changes over time, with some asserting it remains constant for linear, time-invariant systems but varies with frequency.
  • One participant argues that Ohm's Law is applicable only when voltage and current are in phase, while others suggest that it can be treated using complex numbers to account for phase differences.
  • Participants question the validity of using peak voltage and current to determine reactance, given the 90-degree phase difference in AC circuits.
  • There is a mention that instantaneous values in AC circuits do not yield a straightforward application of Ohm's Law, particularly with capacitors.
Participants express differing views on the applicability of Ohm's Law in AC circuits involving capacitors, particularly regarding the use of instantaneous values and the implications of phase differences. The discussion remains unresolved with multiple competing perspectives on the nature of reactance and its derivation.
Some limitations include the dependence on definitions of reactance and the assumptions regarding lossless conditions. The discussion also highlights the complexity of analyzing AC circuits dynamically over cycles rather than at instantaneous moments.
unseensoul
How do we derive the opposition to current flow (AC signal) due to capacitance without using complex numbers?
Is the capacitor's reactance a constant or an average?
If I were to measure the instantaneous voltage across a capacitor and the instantaneous current through it, shouldn't I get its reactance (according to Ohm's Law)?
Why do we get the reactance of the capacitor dividing the peak voltage by the peak current if they are always 90 degrees out of phase?
Xc (reactance) = 1/2 x pi x f x C IF the C is essentially lossless.
R in series with C would give impedance Z = Root of the sum of the squares of Xc and R (vector sum)
Xc is constant at given frequency f.
I = V/Xc.
Xc = Vrms/Irms and as Vrms is proportional Vpk and Irms is prop to Ipk. Xc = Vpk/Ipk
I don't know if you've noticed but you didn't answer any of my questions. However, thanks for reply anyway :)
You generally use differential equations first, and then simplify to complex number notation.
What are your thoughts on this? A capacitor is a physical thing, with the physical dimensions (generally) not changing with applied voltage...
Can you show us the equation you are asking about?
I know that but I'm asking how to fully derive it without any use of complex numbers.
I'm sorry, my question didn't make sense. What I mean is; does reactance changes over time?
What do you mean? What I was asking in here was if the reactance value would be the same as measuring the instantaneous values (voltage and current) at a given time and find their ratio (Ohm's Law).
I believe the correct answer is no, not for LTI (linear, time-invariant)systems. It does change over frequency, though. Usually when you are referring to a reactance, you are referring to a specific test frequency.
Not sure I understand the question, but I think the answer is no. The reactance is the imaginary component of the complex impedance, not the instantaneous magnitude of the impedance.
http://en.wikipedia.org/wiki/Reactance_(electronics )
I don't really know how to explain what I mean :S
However, does Ohm's Law only work when both voltage and current are in phase?
Imagine an AC circuit comprised of a resistor only. We both know that the voltage and current are both in phase. Now, if we want to know the R value we can just apply Ohm's Law at any given time. Obviously such value will also give you the circuit's opposition to current.
If we now replace the resistor with a capacitor how can we manage to get the same current opposition as with the resistor?! Well, we just need to make X equal to R and we are done!
Nonetheless, if we measure the instantaneous voltage (across it) and current (through it) at a given time and work out their ratio (Ohm's Law) we won't get the correct value of the opposition to current. Therefore Ohm's Law doesn't work with instantaneous values in AC circuits where there's a phase difference between the voltage and current.
Lol... I think I've just answered my question although it seems a bit counter intuitive?!
Intantaneous voltage or current is a difficult concept in AC circuits as it suggests a frozen moment in time and DC values which won't exist with a capacitor. It is a circuit element with energy storage and you have to analyse it over one or more AC cycles. The current flow depends on frequency. It has to be analysed dynamically.
Ohm's law works when you treat V, Z and I as complex numbers. There are Real and Imaginary components to each, in general.
Fair enough, but could you tell me why do we get a capacitor's reactance working out the ratio between the Vp and Ip? Why the peak values if they are 90 degrees out of phase? If you apply Ohm's Law directly to instantaneous values and work out their ratio it will fail.
Where does such ratio come from?
  • · Replies 17 ·
  • · Replies 78 ·
