[Q]How can i draw real graph from complex function?
This discussion focuses on visualizing complex eigenfunctions, specifically the function \(\varphi = Ae^{ik_{1}x} + Be^{-ik_{1}x}\), and understanding the transmission coefficient in quantum mechanics. To graph the complex function, one can extract the real part and plot it against the imaginary part, using a 3D graph where the x-axis represents the real part, the y-axis the imaginary part, and the z-axis the magnitude. The transmission coefficient, defined as \(T = |\frac{C}{A}|^2\frac{k_2}{k_1}\), indicates the ratio of transmitted to incident amplitudes, and it is essential to recognize that amplitudes can indeed be complex numbers.
  • Understanding of complex functions and their graphical representation
  • Familiarity with quantum mechanics concepts, particularly wavefunctions
  • Knowledge of transmission coefficients in potential barrier problems
  • Experience with 3D graphing techniques and tools
  • Research methods for visualizing complex functions using software like MATLAB or Python's Matplotlib
  • Study the derivation and implications of the transmission coefficient in quantum mechanics
  • Learn about wavefunction continuity and boundary conditions in quantum mechanics
  • Explore advanced graphing techniques for representing complex data in three dimensions
Students and professionals in physics, particularly those specializing in quantum mechanics, as well as mathematicians and engineers interested in complex function visualization and analysis.
good_phy
For instance,
I have a simple eigen function such as [itex]\varphi = Ae^{ik_{1}x} + Be^{-ik_{1}x}[/itex]
This is complex form which means we can't draw this function on real coordinate.
How can i draw this function? just By taking out real term of complex function?
Second question is what does transmission coefficient means. What exactly i want to know
is how to know amplitude of transmission wave from transmission coefficient in potential
barrier problem? For instance, in problem such that x < a, v = 0 and x >= a, v = c,
Transmission coefficient [itex]T = |\frac{C}{A}|^2\frac{k_2}{k_1}[/itex]
But This expression contains absolute value of ratio A to C, So I'm not sure that This
expression indicate real transmission amplitute C when we know Incident amplitute A.
More over, I'm confusion that whether amplitute of wave can be complex number.
You know that you can write that function in terms of cos and sine right? i.e that wavefunction is a sinosodial one with one term propagating to the right and one propagating to the left.
You must match the inner solution with the outer solution so that the wavefuntion is continuous and has continuous derivative at the boundary. Very standard exercise in intro QM.
In addition, you could plot 3D graph as follows: let the x coordinate be the real part of the input, let the y coordinate be the complex part of the input, and let z be the magnitude of the output. You can change this around to get the complex part of the output, etc.
  • · Replies 17 ·
