Magnetic Field due to rotating disks
The discussion centers on the magnetic field generated by two identical rotating disks with angular velocity omega, rotating in the same direction about the z-axis. It is established that the magnetic fields produced by the disks do not simply cancel or double at all points; rather, their interaction depends on the spatial configuration. Specifically, at certain points, the fields may cancel or reinforce each other, which can be analyzed using the right-hand rule and the superposition principle.
  • Understanding of magnetic fields generated by rotating charged bodies
  • Familiarity with angular velocity and its implications in electromagnetism
  • Knowledge of the right-hand rule for determining magnetic field direction
  • Concept of superposition principle in physics
  • Study the effects of charge density on magnetic field generation in rotating systems
  • Explore the application of the right-hand rule in complex magnetic field configurations
  • Investigate the superposition principle in electromagnetic fields
  • Examine case studies involving multiple rotating charged disks and their magnetic interactions
Physics students, educators, and researchers interested in electromagnetism, particularly those focusing on the behavior of magnetic fields in systems with rotating charged objects.
E&M
There are two rotating disks which rotate with angular velocity omega in the same direction about a z axis. Will the magnetic field at the center of those two disks cancel out or will it be twice the field due to one of the disks? This is a part of a bigger problem. So, I haven't posted the relevant equations and attempt as I have already figured out other things. Thanks in advance.
What field point(s) is this question in regard to? Unless the two disks are superposed, the fields will neither completely cancel or double at all field points. However, there are some points at which one of those will happen.
Are the disks identical (do they carry the same charge density?)? Assuming the question is about a point on the z-axis, you can use the right hand rule to determine the direction of each constituent field and then use the superposition principle to determine whether they cancel or double.
16K
