First Integrals in Classical Mechanics: Definition & Procedure
  • Context: Graduate
  • Thread starter Thread starter KFC
    Integrals
First integrals in classical mechanics are defined as quantities that remain constant over time, represented by the equation f(q_1, q_2, ...; \dot{q}_1, \dot{q}_2, ..., t) = const. This definition encompasses three key aspects: (1) any time-invariant quantities qualify as first integrals, (2) generalized coordinates that are cyclic in Lagrangian equations are considered first integrals, and (3) if the Hamiltonian is not explicitly time-dependent, energy is a first integral. The process of finding first integrals involves reducing second-order differential equations to first-order equations through integration.
  • Understanding of Lagrangian mechanics and equations of motion
  • Familiarity with Hamiltonian mechanics and energy conservation
  • Knowledge of differential equations, particularly second-order equations
  • Concept of cyclic coordinates in classical mechanics
  • Study the derivation and application of Lagrange's equations of motion
  • Explore Hamiltonian mechanics and its implications for energy conservation
  • Learn techniques for solving second-order differential equations in classical mechanics
  • Investigate the concept of second integrals and their role in motion problems
Students and professionals in physics, particularly those focused on classical mechanics, as well as researchers interested in the mathematical foundations of motion and energy conservation principles.
KFC
In my text of classical mechanics, it reads: for all relations
[tex]f(q_1, q_2, \cdots; \dot{q}_1, \dot{q}_2, \cdots, t) = const.[/tex]
are called first integrals. This definition is very vague. I wonder if it means
1) Any quantities which are not changing with time are called "first integrals" ?
2) If a generalized coordinate is cyclic in Lagrangian equations, can I say this coordinate is one of the first integrals?
3) If the Hamiltonian is not time-dependent explicitly, can I said the energy is one of the first integrals?
What is the general procedure to find all first integrals?
BTW, if there is so called *first* integrals, so is there *second*-integrals?
Motion problems involve second order differential equations. First integrals are the result of integrating one time, to reduce the second order equations to first order differential equations. Thus if you look carefully at the form you gave,
f(q1,q2,q2,...q1dot,q2dot,q3dot...,t) = const
you will see that it does not involve any second derivatives; it is a "first integral" by definition. If you are able to find a "second integral" you will have solved the equation of motion.
1), 2) and 3) are all correct. Starting from Lagrange's equations of motion, a second order DE, if you have found a 'first integral' of motion, then one of the integrations has already been performed and your equation of motion effectively becomes a first order equation. I think that's the origin of the term.
  • · Replies 43 ·
