Rotating mass system with a forward velocity and acceleration
The discussion focuses on a solid rotating body with a moment of inertia I, which maintains a constant angular velocity w while moving in a straight line at velocity v. When the system undergoes an acceleration a, the objective is to derive the equation for the force vector F acting on the axis of rotation. The problem involves the Coriolis effect, akin to the behavior of a spinning gyroscope when subjected to lateral forces. Key equations include the torque vector N, defined as N = r x F, and the application of Newton's laws to account for inertial forces in a moving reference frame.
  • Understanding of rotational dynamics and moment of inertia
  • Familiarity with angular velocity and linear acceleration concepts
  • Knowledge of the Coriolis effect in rotating systems
  • Proficiency in applying Newton's laws in non-inertial reference frames
  • Study the derivation of the Coriolis force in rotating systems
  • Explore advanced topics in rotational dynamics, focusing on gyroscopic motion
  • Learn about the mathematical modeling of forces in non-inertial frames
  • Investigate applications of torque in mechanical systems and their implications
Students and professionals in mechanical engineering, physics, and robotics who are dealing with dynamics of rotating systems and forces in non-inertial reference frames.
gmacmilla
I have a
solid rotating body with moment of inertia I rotating at a constant angular velocity w
body is spinning about an ideal bearing located at its CG, the system is also moving in straight line at a velocity v when it suddenly undergoes an acceleration a. I want to find an equation for the Force vector F placed on the axis of rotation by the accelerating rotating mass.
** angular velocity remains the same **
This problem has something to do with the coriolis effect and is similar to taking a spinning gyroscope and pushing it strongly in one direction. It puts a side force on your hand
Not sure where to start. I have the angular velocity equations as well as the forward velocity and acceleration equations of . A good start would be helpfull please!
Consider the pivot point of the rotating body. The torque vector, N, is related to the applied force by N = r x F where r is the distance from the pivot point to the center of mass of the system. Also, the acceleration is linear so Newton's laws become F - ma = m times the second time derivative of the postion vector relative to the moving reference frame, and a is the acceleration of the system. The ma term is an inertial force and not a real force and depends on the acceleration of the moving coordinate system. F = mg in this case and points vertically downward, and ma points in a horizontal direction. The effective force acting on the pivot point is the vector addition of these two components.
  • · Replies 25 ·
  • · Replies 30 ·
  • · Replies 60 ·
  • · Replies 19 ·
