| Thread Closed |
Converging series |
Share Thread | Thread Tools |
| Jan9-09, 07:19 AM | #1 |
Converging series
Show that the following series converges: 2. Relevant equations Sum of n=1 to n=infinity of [(n+1)/(n^2 +1)]^2 3. The attempt at a solution I thought about using the ratio test, so if the limit as n tends to infinity of a(n+1) / a(n) < 1, then a(n) - the series - would converge. Once i put a(n+1)/a(n), i don't really know how to continue. |
| Jan9-09, 07:32 AM | #2 |
[tex]\sum_{n=1}^{\infty}\frac{n+1}{(n^2+1)^2}[/tex]
I would try to use the comparison test to establish the convergence of this series. My first guess is that it is convergent, so i will try to compare it to another convergent series. I would start off by noticing that: [tex]n^3\leq n^4[/tex] THen it is clear that: [tex]n^3<n^4+2n^2+1=(n^2+1)^2[/tex] One more step towards the answer: Taking the reciprocal of the above we get: [tex]\frac{1}{n^3}>\frac{1}{(n^2+1)^2}[/tex] Now, all u need to do is multiply both sides of the inequality by n+1, try to manipulate a little bit the left side and justify ur answer. I will stop here, and see whether u can get it done? |
| Jan9-09, 07:45 AM | #3 |
i know for the comparison test, you assume that a(n)<= k.b(n)
Then if b(n) is convergent, a(n) is also convergent. However i still dont see how i can get my series to be <= to a constant times another series. |
| Jan9-09, 07:51 AM | #4 |
Converging series
The comparison test says: Let [tex]\sum b_n,\sum a_n[/tex] be two series with positive terms.
(i) If [tex]\sum b_n[/tex] is convergent, and if [tex]a_n<b_n[/tex] for some n>N, then the series [tex]\sum a_n[/tex] also converges. (ii)If [tex]\sum b_n[/tex] divergent, and if [tex]b_n<a_n[/tex] for some n>N, then [tex]\sum a_n[/tex] is also divergent. But, what u are saying there is also true, since if [tex]\sum b_n[/tex] converges, so does the series [tex]\sum k*b_n[/tex] where k is a constant. |
| Jan9-09, 08:06 AM | #5 |
| Jan10-09, 06:55 AM | #6 |
Recognitions:
We can't use sutupidmath's particular example for this one, as its the entire expression that is squared, not just the denominator =[
However the problem is still easily tackled. First, lets consider the expression under the squared sign. That expression is larger than the analoguous expression with only n in the numerator, ie the +1 omitted. Then, dividing all terms by n, we need that expression is [itex]1/( n + 1/n) [/itex] After we square that, it becomes [itex]1/ (n^2 + f(n))[/itex] where f(n) are some positive terms. Hence, this expression is in turn larger than the series for [itex]1/n^2[/itex]. And we know that converges. |
| Jan10-09, 08:03 AM | #7 |
| Jan10-09, 10:04 AM | #8 |
with
[tex]\left[\frac{n+1}{n^2+1}\right]^2[/tex] You can still do the same thing. Divide both numerator and denominator inside the square by n2 and you get [tex]\left[\frac{\frac{1}{n}+ \frac{1}{n^2}}{1+ \frac{1}{n^2}}\right]^2[/tex] Now it should be clear that, while the numerator goes to 0 as n goes to infinity, the denominator goes to 1. The fraction goes to 0 and, because x2 is continuous, so does its square. |
| Jan11-09, 02:35 PM | #9 |
[tex]\lim_{n \rightarrow \infty}(\frac{n+1}{(n^2+1)^2})=0 [/tex], so the series are convergent. If it wasn't equal to zero, than the series are divergent.
Regards. |
| Jan11-09, 04:21 PM | #10 |
A necessary but not sufficient condition for a series [tex]\sum a_n[/tex] to converge, is if [tex]\lim_{n\rightarrow \infty}a_n=0[/tex] A simple example is the harmonic series [tex]\sum\frac{1}{n}[/tex] 1/n -->0 as n-->infinity, but we know that the harmonic series diverges. |
| Jan18-09, 12:58 PM | #11 |
I'm having trouble with the convergence of series myself, so I'm only asking. |
| Jan18-09, 02:30 PM | #12 |
Yes, but my point was that whatever "comparison" you get for [itex](n+1)/(n^2+1)[/itex], compare [itex][(n+2)/(n^2+1)]^2[/itex] to its square.
Certainly [itex](n+1)/(n^2+1)< 2n/(n^2+1)[/itex] and it is not too hard to show that [itex]n/(n^2+1)[/itex] itself is less than 2/n. That itself would not be enough to show that [itex](n+1)/(n^2+1)[/itex] itself converges because 2/n does not converge. But it does show that [itex][(n+1)/(n^2+1)]^2< 4/n^2[/itex] and [itex]4/n^2[/itex] does converge. |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Converging series
| converging series | Calculus & Beyond Homework | 1 | ||
| Converging/Diverging Series | Calculus & Beyond Homework | 2 | ||
| Converging Series | Calculus & Beyond Homework | 3 | ||
| Converging | Advanced Physics Homework | 1 | ||
| Converging infinite series | General Math | 9 | ||
