| Thread Closed |
simple solenoid problem |
Share Thread | Thread Tools |
| Jan10-09, 06:39 PM | #1 |
the question can be found here: http://www.mailfreeonline.com/uploader/CED0D65C.jpg 2. Relevant equations ampere's law 3. The attempt at a solution a. (is B the magnetic field?) B = uI/L; u = 4pi x 10^-7, I = 1, L = 2pi x 0.1 so B = 2 x 10^-6 ^ can anyone confirm this? b. B = uNI/L (i'm guessing L is the radius this time). i don't know how to incorporate the length of the solenoid into this equation. i don't know the assumption either. c. is this the same as part b but with numbers plugged in? |
| Jan10-09, 08:16 PM | #2 |
Recognitions:
I looked in mine from the 1960's and it has B = uIn, where n is the number of turns per unit length. It looks like the value of B applies anywhere near the center of the coil. My reading is that in (b) you have to derive the formula and in (c) use it to calculate the strength of the magnetic field. If your textbook doesn't have the derivation, you might look for a copy of my old Engineering Physics book - "Physics" by Halliday and Resnick. It is a big blue one. The derivation begins with Ampere's Law as a path integral. |
| Jan11-09, 05:46 AM | #3 |
| Jan11-09, 02:29 PM | #4 |
simple solenoid problemFlux density sounds a bit funny. Its been a while since I've done this, so I may have simply forgotten what the term meant, but magnetic flux is the "bombardment" or flow of a magnetic field through an area. Flux density would depend on what density is being referred to (length, area, volume...); if its area, then it should technically simply be the magnetic field. |
| Thread Closed |
| Tags |
| magnetism, oxford, solenoid |
| Thread Tools | |
Similar Threads for: simple solenoid problem
| solenoid problem | Introductory Physics Homework | 6 | ||
| Solenoid Problem | Introductory Physics Homework | 3 | ||
| solenoid problem | Introductory Physics Homework | 8 | ||
