Why eigenvalue specification reduces the no. of LI equations?
  • Context: Graduate
  • Thread starter Thread starter neelakash
    Eigenvalue
The discussion centers on the relationship between eigenvalue specification and the reduction of linearly independent equations in the context of the eigenvalue problem represented by the equation [A - λI]X = 0, where A is an NxN matrix and X is an Nx1 vector. When one non-degenerate eigenvalue is specified, the number of linearly independent equations decreases to (N-1) due to the singularity of the matrix [A - λI], which has a maximum rank of (N-1). The rank reduction is explained through the algebraic multiplicity of eigenvalues, where distinct eigenvalues ensure that each matrix [A - xkI] has rank (N-1).
  • Understanding of eigenvalue problems and linear algebra concepts
  • Familiarity with matrix rank and determinants
  • Knowledge of algebraic multiplicity of eigenvalues
  • Experience with matrix operations and properties
  • Study the concept of algebraic multiplicity in eigenvalue problems
  • Learn about the implications of matrix rank in linear transformations
  • Explore the properties of singular matrices and their determinants
  • Investigate examples of eigenvalue problems with distinct and repeated eigenvalues
Mathematicians, physicists, and engineers working with linear algebra, particularly those involved in eigenvalue analysis and matrix theory.
neelakash
Hi everyone, I am stuck with the following for last couple of days.
Many books mention during the development in the idea of Eigenvalue problem: say, you have the equation
[tex][\ A-\lambda\ I]\ X=\ 0[/tex] where A is an NxN matrix and X is an Nx1 vector.
The above consists of n equations.Say,all eigenvalues are non-degenerate.
If you specify one of the non-degenerate eigenvalues,the number of linearly independent equations will be (N-1).This is written in book.I am looking for the explanation.
The linear independence of the equations come from the vectors in the matrix [tex][\ A-\lambda\ I][/tex].Since,the matrix [tex][\ A-\lambda\ I][/tex] is singular,its rank can be at most (N-1).Means,the maximum number of the linearly independent vectors in the matrix A after specifying one of its eigenvalues is (N-1).At least one of the vectors can be expanded in terms of the (N-1) vectors.
I find it difficult to see how the specification of the eigenvalue results in this.It is clear that in specifying the eigenvalue,all the matrix elements become known to us.And we can readily calculate its deerminant=0.That way it is OK.But how do we know the rank is precisely (N-1) and not (N-2) or (N-3)...etc.?
-Please take part in the discussion so that the thing becomes clear.
Neel
I assume you have n eigenvalues. Your result only holds when they are all different. If x is an eigenvalue of (algebraic) multiplicity k (A-lambda*I)^k has rank N-k. It is also possible that (A-lambda*I)^l has rank N-k for some l=1,2,...,k-1. This helps to keep things interesting. We can see this because (A-x1*I)...(A-xN*I) has rank 0. When eigenvalues are distinct we conclude each (A-xk*I) has rank N-1.
example the matrix
{{x,1}
{0,x}}
The eigenvector x is multiplicity 2 (A-x*I) has rank 1 (A-x*I)^2 has rank 2
example the matrix
{{x,0}
{0,x}}
The eigenvector x is multiplicity 2 (A-x*I) has rank 2
