Can New Reactants Reduce Nitric Oxide Pollution?
  • Thread starter Thread starter ninjaDUDE
    Experiment
This discussion focuses on a proposed experiment aimed at reducing nitric oxide pollution by identifying new reactants that can form harmless compounds. The project emphasizes the need to observe the relative strength of chemical bonds between nitrogen and nitric oxide to determine ideal alternatives. The goal is to find stable compounds that can replace nitric oxide, which contributes to photochemical smog and toxic ozone formation. If successful, this research could lead to practical solutions for mitigating air pollution in urban environments.
  • Chemical bonding principles
  • Understanding of nitric oxide and nitrogen dioxide reactions
  • Knowledge of photochemical smog formation
  • Basic experimental design in chemistry
  • Research the mechanisms of nitrogen and nitric oxide bonding
  • Investigate alternative reactants for nitric oxide reduction
  • Study the effects of photochemical reactions on air quality
  • Explore methods for measuring reaction rates in chemical experiments
Chemists, environmental scientists, and researchers focused on air quality improvement and pollution reduction strategies.
ninjaDUDE
Is this a feasible experiment?
Preliminary Proposal:
Observing the Relative Strength of Chemical Bonds with Nitrogen and Nitric Oxide in Order to Determine the Ideal Compound or Element to Break and Form New Harmless Compounds as to Replace the Existing Pollutant - Nitric oxide
One of the main sources of pollution in the world today is the oxidation of exhaust gases. Many large cities have a photochemical smog which is in the air, giving it a brownish tint. This smog is produced from the exhaust released by cigarettes, automobiles, and power plants. When the nitric oxide is released, it bonds with oxygen thus forming nitrogen dioxide; however intense sunlight makes the compound decompose back into nitric oxide and simultaneously freeing an extremely reactive oxygen atom which may form highly toxic ozone. This project will investigate other possible reactants that would produce a more stable compound (relative to that of nitric oxide) that would be harmless in order to successfully remove its being a threat to the environment. If this is found to be possible then it may be practical to release large amounts of this substance into the air at the proper rate to compensate for the amount of pollutant already existing, and yet to come, into the air. To verify whether a certain element or compound is capable of this and which one is best, one would compare and contrast reaction rates of their bonding with nitrogen and breaking the bonds of a fixed amount of nitric oxide.
oh, and hi mr. reeves in case you're checking this
10K
  • · Replies 19 ·
11K
  • · Replies 21 ·
32K
11K
