What is the Amplitude of a Pendulum?
  • Context: High School
  • Thread starter Thread starter potmobius
    Amplitude Pendulum
The amplitude of a pendulum can be determined through both measurement and calculation using Newton's laws. For small displacements (approximately 5 degrees), the period can be calculated using the formula T = 2π√(l/g), where l is the length of the pendulum and g is the acceleration due to gravity. For larger amplitudes, the period is expressed as an elliptic integral of the first kind, T(ϕ₀) = 4√(l/g) ∫₀^(π/2) dψ/√(1-k²sin²ψ), where k = sin(ϕ₀/2). This indicates that the period cannot be expressed using elementary functions for arbitrary amplitudes, but can be approximated using series expansions.
  • Understanding of simple harmonic motion
  • Familiarity with Newton's laws of motion
  • Knowledge of elliptic integrals
  • Basic calculus for integration and series approximations
  • Study the derivation of the formula for the period of a pendulum using small angle approximation
  • Explore elliptic integrals and their applications in physics
  • Learn about series approximations for functions and their convergence
  • Investigate the effects of amplitude on the period of oscillation in pendulum systems
Physics students, educators, and anyone interested in understanding the dynamics of pendulum motion and harmonic oscillators.
potmobius
How can one determine the amplitude, frequency and period of an amplitude? this is not homework, i was just curious, because i knew how to find the time using the 2 pi sqrt(l/g), but wanted to know about this, since i am learning about waves and harmonic motion! Help would be appreciated. Thanks!
P.S. this is my first time using physics forums, so tell me if i should change the way i ask a question or if i made any kind of mistake :P
Determine as in measure? Or as in calculate using Newton's laws?
The [tex]2\pi \sqrt{\frac{l}{g}}[/tex] formula is only good for small amplitude displacements around 5 degrees, this is the harmonic approximation.
Lets look how we get this. Newton says, for the tangential component:
[tex]ml\ddot \varphi = - mg\sin\varphi[/tex]
Where [tex]\varphi[/tex] is the angle between the vertical and the string of the pendulum.
So the equation of motion for the pendulum:
[tex]\ddot\varphi = -\frac{g}{l}\sin\varphi[/tex]
Now as we see this is a non-linear differential equation. For small displacements (i.e. small angles) that is:
[tex]\sin\varphi \approx \varphi[/tex]
So:
[tex]\ddot\varphi = -\frac{g}{l}\varphi[/tex]
As we see this equation describes simple harmonic motion, and we can extract the frequency of oscillations:
[tex]\omega^2=\frac{g}{l} \Longrightarrow T=\frac{2\pi}{\omega}=2\pi\sqrt{\frac{l}{g}}[/tex]
So we obtained the formula for small displacements of the pendulum, and we can see that it (of course) doesn't depend on the amplitude...
Now if the displacements arent small we cannot approximate the sine like we did.
In this case after integrating the equation once and some manipulation, we obtain for the period:
[tex]T(\varphi_0)=4\sqrt{\frac{l}{g}}\int_0^{\frac{\pi}{2}} \frac{d\psi}{\sqrt{1-k^2\sin^2\psi}}[/tex]
Where [tex]k=\sin\left(\frac{\varphi_0}{2}\right)[/tex] Here \varphi_0 is the amplitude(maximum displacement) of the pendulum.
As we see this is an elliptic integral of the first kind. So the period of the pendulum at arbitrary amplitudes cannot be given using elementary functions.
We can however use a series approximation for the elliptic integral. Using this we get:
[tex]T(\varphi_0)=2\pi\sqrt{\frac{l}{g}}\sum_{n=0}^{\infty}\left[\frac{(2n-1)!}{(2n)!}\sin^n\frac{\varphi_0}{2}\right][/tex]
If the amplitude is still small but not that big, then we can further approximate the sines (now I do it upto fourth order of the amplitude):
[tex]T(\varphi_0)=2\pi\sqrt{\frac{l}{g}}\left[1+\frac{1}{16}\varphi_0^2+\frac{11}{3072}\varphi_0^4 +\dots\right][/tex]
So we can conclude that, we can't get an exact solution even for such trivial and simple configurations...
  • · Replies 36 ·
