What is the Damping Constant for a Spring in Sea Water?
  • Context: Undergrad
  • Thread starter Thread starter zaurus
    Constant Damping
The discussion focuses on determining the damping constant for a spring-mass-damper system submerged in seawater. The system equation is confirmed as my'' = mg - by' - ky, where 'b' represents the damping coefficient influenced by seawater. To accurately calculate 'b', one must consider the flow dynamics around the hanging mass, which complicates the process compared to simpler geometries like spheres. A practical approach to determine 'b' involves conducting experiments in both air and seawater to measure the spring constant 'k' and the damping effects.
  • Understanding of damped harmonic oscillators
  • Familiarity with spring-mass-damper systems
  • Basic knowledge of fluid dynamics, particularly in seawater
  • Experience with experimental measurement techniques
  • Research the salinity of seawater and its impact on damping coefficients
  • Learn how to calculate the spring constant 'k' using experimental methods
  • Conduct experiments to measure damping in both air and seawater
  • Investigate the damping coefficients for various shapes in different fluids
Mechanical engineers, physics students, and researchers involved in fluid dynamics and oscillatory systems will benefit from this discussion.
zaurus
Hi,
I am working on a problem with a free hanging mass attached to a spring and damper in parallel. I believe my system equation is as follows:
My questions:
1) It has been a while since I've taken this course and just wanted to confirm I wrote my system equation correctly...for some reason I remember the spring and dampers in parallel add (opposite of those in circuits).
2) Where can I find or calculate a value for damping coefficient, b, assuming damping is caused by seawater ?
Your equation is correct :D
It is basically a 1D motion, of a damped driven harmonic oscillator..
But if you want to do it in sea water, then it won't be correct, since you have to take into account the flow around the hanging mass , which is not so easy. For a sphere it is easy to calculate the frequency shift due to the flow, because of the symmetry, but for another asymmetric object its not so easy...
You could easily determine the damping coefficient from a simple home-made experiment.
- Research what the salinity of sea water is.
- Mix table salt and water together to the same concentration.
- Given that you know the mass of the object, m.
- Take measurements of travel distance and time for the following tests:
- First, suspend the weight onto the spring in open air (not sea water) to determine the spring constant, k.
- Second, suspend the weight onto the spring in sea water to determine the damping coefficient, b.
For comparison, you might find from Google the damping coefficient for an object in pure water. I would imagine the damping b will be similar (but less) as that for sea water.
  • · Replies 131 ·
9K
  • · Replies 27 ·
  • · Replies 21 ·
