The discussion revolves around the voltage characteristics of single-phase lines derived from a three-phase line, specifically addressing the line-to-line voltage of a 25 kV three-phase system and its conversion to single-phase voltage. Participants explore theoretical and practical aspects of voltage distribution in electrical systems.
- Technical explanation
- Debate/contested
- Louie questions whether the voltage of a single-phase line remains at 25 kV or drops to 14.4 kV when derived from a 25 kV three-phase line.
- One participant states that typically, the line-to-neutral voltage is calculated as 14.4 kV, while the line-to-line voltage remains at 25 kV, indicating that the phases can split in various configurations.
- Another participant clarifies that a single-phase line requires a neutral to create a complete circuit, asserting that the voltage differential between the line and neutral is +/- 14.4 kV.
- Mahadev argues that for distribution purposes, only line voltages are typically used, and that the 25 kV will not be split directly into single-phase but will be stepped down first, with the single-phase voltage depending on transformer ratings.
- A later reply discusses the common practices in urban and suburban areas in the USA regarding single-phase distribution and the use of a multiple grounded neutral (MGN) system, noting differences in European practices.
Participants express differing views on the voltage characteristics of single-phase lines derived from three-phase systems, with no consensus reached on the exact voltage values or methods of distribution.
The discussion includes assumptions about voltage definitions and distribution practices that may vary by region, as well as the implications of transformer ratings on single-phase voltage outputs.
