Finding the eq. of all tangent lines on a curve
The problem involves finding the equations of all tangent lines to the curve defined by y = x^2 + 2x that also pass through the point (3, 14). The original poster specifies not to use derivatives in their approach.
  • Participants discuss the correct form of the curve, with some questioning whether the original equation was miswritten. There is a suggestion to clarify the equation of the curve before proceeding.
The discussion has clarified the equation of the curve as y = x^2 + 2x. Some participants have begun outlining potential steps to find the tangent lines, including considerations of slope and points of tangency, though no consensus on a method has been reached.
There is an explicit constraint against using derivatives, which may affect the approaches discussed. The original poster expresses uncertainty about how to start the problem.
Gus_Chiggins
Problem: Find the equations of all tangent lines to the curve
y = x + 2x so that also go through the point (3, 14).
2. Do not use a derivative
3. I don't even know where to start. I searched my book there isn't really available. Any help would be much appreciated
Is that really supposed to be y=x+2x, or have you mis-typed something?
What's the correct equation? The "curve" y = x + 2x is a straight line that doesn't go through (3, 14), so no tangent can go through this point either.
Should it be y = x^2 + 2x?
sorry everybody,
yes I meant to say
y=x^2 + 2x
sorry
OK, now that we've gotten that out of the way...
Let [itex](x_0, y_0)[/itex] be the point of tangency on the graph of the curve. BTW, you have drawn the graph, right?
At the point of tangency, the tangent line has to extend from [itex](x_0, y_0)[/itex] to (3, 14).
Here is an outline of the steps you'll need to carry out for this problem:
1. Find the slope of the line from [itex](x_0, y_0) = (x_0, x_0^2 + 2x_0)[/itex] to (3, 14).
2. By calculating the derivative and evaluating it at [itex]x_0[/itex], find the slope of the tangent line.
3. Equate the value you got in step 1 with the value from step 2, and solve for [itex]x_0[/itex]. (I got two values for [itex]x_0[/itex].)
4. Find the associated y value for each value of [itex]x_0[/itex] from step 3.
5. Using each point [itex](x_0, y_0)[/itex], find the equation of the line from [itex](x_0, y_0)[/itex] to (3, 14). There are two distinct equations.
Is that enough of a hint?
