How to Calculate Entropy Change for Different Scenarios Involving a Can of Coke?
This discussion focuses on calculating the change in entropy for a can of Coke under various scenarios. The first scenario involves a single can at an initial temperature of 5 degrees Celsius reaching thermal equilibrium at 40 degrees Celsius, resulting in an entropy change of 5198.6 J/K using the formula ΔS = Cp ln(Tf/Ti). The second scenario examines two cans in thermal contact, yielding an equilibrium temperature of 22.5 degrees Celsius and an entropy change of 2321.8 J/K. The third scenario involves a can dropped from a height of 50 meters into a pond, where the relationship between potential energy and heat transfer is discussed, emphasizing the need to convert temperatures to Kelvin for accurate calculations.
  • Understanding of thermodynamics principles, specifically entropy and heat transfer.
  • Familiarity with the formula ΔS = Cp ln(Tf/Ti) for calculating entropy change.
  • Knowledge of potential energy calculations, particularly U = mgh.
  • Ability to convert temperatures from Celsius to Kelvin for thermodynamic calculations.
  • Research the implications of thermal equilibrium in thermodynamics.
  • Learn about the relationship between potential energy and heat transfer in thermodynamic systems.
  • Explore advanced entropy calculations involving multiple bodies in thermal contact.
  • Study the laws of thermodynamics, particularly the second law regarding entropy changes.
Students and professionals in physics, thermodynamics, and engineering fields who are interested in understanding entropy changes in thermal systems, particularly in practical applications involving heat transfer and energy conservation.
Discostu19
Heat and Entropy Change HELPPPP!
Calculate change in entropy of the universe for:
1] A can of coke, at initial temperature of 5 degrees C, with heat capacity 2500JK-1, is allowed to reach thermal equilibrium with its surroundings at 40 degrees C
2] Two Cans of coke at 5 degrees C and 40 degrees C are placed in thermal contact with each other inside a cool bag where they are thermally insulated from their surroundings and allowed to equilibrate
3]One of the above coke cans at 40 degrees C weighing 250g is dropped from a height of 50m into a shallow pond of negligible depth which is also at 40 degrees C
Attempt
1] using delta S = Cpln(Tf/Ti)
giving 2500xln(40/5)
=5198.6JK-1
ii]
using Tf=(C1T1+C2T2)/C1C2
[2500x40]+[2500x5]/2500+2500
=22.5 degrees C
therefore delta S = C1ln(Tf/T1)+C2ln(Tf/T2)
=2500ln(22.5/40)+2500ln(22.5/5)
=2321.8
so far so gd?
for iii] do i use delta S = P.E / temp of surrounding ?
For 1), you need to change the tempratures to kelvin units.
For 3), if I understand the question correctly, you use the connection between energy and heat transfer, Q=U+W, U=mgh, the work that being done by the bodies, W, not sure how to get it.
Anyway, dQ=SdT+TdS, there isn't a change in the tempratures, and the change is entropy is what you're after, so dQ=TdS, dS=dQ/T, find the change in the heat transfer and I believe your'e done, not sure though.
cheers :)
