Kichoff Simultaneous Equations
The discussion revolves around applying Kirchhoff's laws to analyze a circuit with multiple loops and currents. The original poster seeks guidance on forming equations for a circuit loop that lacks an EMF and is uncertain about the number of equations needed for the analysis.
  • Participants discuss the necessity of labeling currents in different segments of the circuit and the formation of equations based on Kirchhoff's laws. Questions arise regarding the assignment of currents and the implications of having multiple loops and nodes.
Participants are actively engaging with the problem, offering suggestions for labeling currents and forming equations. There is acknowledgment of the complexity involved in setting up the equations, and some participants express a clearer understanding of the relationships between the currents as the discussion progresses.
There is mention of specific circuit components and the need to account for multiple currents at nodes, which may complicate the analysis. The original poster is also balancing this homework task with their studies in Product Design.
jase951
I what to know how I form an equation for the middle loop, as there is no EMF in that part. Or, how do I go about forming the equations? Also, am I right to say that I should have 3 equations?
http://www.theground.co.uk/CCF18012009_00000.jpg
Thanks!
Jase
In any loop, the sum of the voltage drops (IR) and the EMFs must be zero.
One way is to assign each branch its own current. You'll need as many equations as branches.
Thanks!
So the middle section, we'd have 0V = (Ix20) + (Ix10) + (Ix8) + (Ix20)?
Yes, but each segment of that loop will have a different current. And take care with signs when you add up the voltage drops.
Thanks for the reply.
I'm trying it again. I've updated the image.
I have managed to have do this with 2 loops, but the the 3 loops. Using Kichoff's second law, I'll have 3 equations I understand.
What I am confused about is where I need to lable the current changes to enable me to use Kichoff's first law.
Thanks!
I would label each segment of the circuit with its own current. I see six separate segements, thus I'd have six currents. Then I'd use 3 loops and 3 nodes to produce my equations. (It's not as hard as it sounds.)
Another thing I found helpful when I took this class is, once you follow Doc Al's advice, to set up all the equations in a matrix. It helps make the algebra easier! :smile:
I would assume that the 6 currents would be that of where the resitors are. where would the 6th be?
For the first loop on the left I have:
200V = 10.I1 (thus I1 = 10A).
2nd loop I have:
0V = 8.I2 + 10.I1 + 20.I3 + 20.I5
3rd:
-125V = 30.I4 + 20.I5
For the nodes, and K's 1st Law:
I3 + I4 = I5
And I don't understand how to get the other 2 when I have 2 currents coming out of the node: I5 = I4 + I2 ?
I've got to understand this, doing a Product Design degree. Thanks.
The 6th current will be through E1.
Good.
2nd loop I have:
Good.
3rd:
Good.
I3 + I4 = I5
Good.
That works.
Get one more node equation (which will involve the 6th current).
Thanks!
So I6 + I2 = I1.
I should be able to do the algebra from these.
Could you tell me why you would have I6 there, because of the EMF? As I thought that that current through the EMF would be the same as I1 - or is it because the bottom node is split?
Thanks again!
jase951 said:
So I6 + I2 = I1.
That works.
Because the current splits. (From the above equation, the only way that I6 = I1 would be if I2 = 0.)
Whenever you have a node, assume that each segment intersecting that node has its own current.
I'm understanding it now. Many Thanks again! :)
  • · Replies 28 ·
