A few problems regarding motion
  • Thread starter Thread starter I R GOOD
    Motion
The discussion revolves around a problem involving the motion of a turtle described by a quadratic position function along the x-axis. Participants are tasked with finding the turtle's initial conditions, determining when its velocity reaches zero, and calculating the time taken to return to the starting point and to reach a specific distance from it.
  • Participants attempt to calculate initial position, velocity, and acceleration from the given position function. Questions arise regarding the correctness of the coefficients used in the equations, particularly a potential typo in the acceleration term. There is also discussion about the application of the quadratic formula for determining the time to return to the starting point.
Some participants have provided corrections to initial calculations, and there is ongoing exploration of the implications of the identified typo. The conversation reflects a mix of attempts to clarify the problem setup and to verify calculations without reaching a consensus on the final answers.
Participants are working under the constraints of the original problem statement, which includes a potential typo in the acceleration term that may affect the calculations. The initial position is noted to be at 50 cm, which is relevant for the calculations of distance and time.
I R GOOD
A turtle crawls a straight line, which we call the x-axis with positive direction to the right.Equation for the turtle's position as a function of time
is x(t)=50,0cm + (2,0cm/s)t - (0,625cm/s^2)t^2a.) find the turtle's initial velocity, initial position, initial acceleration
b.) at what time t is the velocity of the turtle zero (derivation?)
c.) how long after does it take the turtle to return to it's starting point
d.)At what time t is the turtle a distance of 10,0cm from it's starting poin
a.) Initial position at x(0)
50cm +(2cm/s)(0) -(0,065cm/s)(0)
=50cm
Initial velocity
x'(0) =0 + (2cm/s)(1) -(0,065cm/s^2)(2*0)
=2cm/s
x''(0) = 0 + (-0,065cm/s^2)(2)
= -0,125cm/s^2
b.)
x'(t)= 0 + (2cm/s)(1) - (0,065cm/s^2)(2t)
then x'(t) = 0
2cm/s - (0,0625cm/s^2)(2t) = 0
1cm/s =(0,0625cm/s^2)(t)
1cm/s / -0,0625cm/s^2=t
= -16sc.) how long after does it take the turtle to return to it's starting point
I tried
(-0,065cm/s^2)(t^2) + (2cm/s)(t) + 50cm = 0
QUADRATIC FORMULA
got either -16,49... or 48,3...
but answer should be 32ssame with d.)
Welcome to PF.
Maybe there was a typo in the problem?
Maybe it should have been .0625 and not .065 in the statement?
Hello and thank you.
I double checked, and yes it was indeed a typo. No wonder... :)
a.) and b.) are now correct, but am I doing something wrong in c?
The starting point is at 50 cm.
