Calculating the pressure of a hailstone
  • Thread starter Thread starter pentazoid
    Pressure
The discussion focuses on calculating the average pressure exerted by hailstones on a window pane during a hailstorm. Given hailstones with an average mass of 2 grams and a speed of 15 m/s striking at a 45-degree angle, the pressure is calculated using the formula P = m(-2vx)/(Δt) * N/A. The hailstones hit the window at a rate of 30 per second over an area of 0.5 m². The calculated pressure can be compared to atmospheric pressure by taking the ratio of the two values.
  • Understanding of basic physics concepts such as force and pressure
  • Familiarity with the equations of motion and vector components
  • Knowledge of unit conversions, particularly between grams and kilograms
  • Ability to perform trigonometric calculations, specifically cosine for angle adjustments
  • Research the derivation of pressure formulas in fluid dynamics
  • Learn about atmospheric pressure and its standard value at sea level
  • Explore the effects of angle of impact on pressure calculations
  • Investigate real-world applications of pressure calculations in meteorology
Students studying physics, particularly those focusing on mechanics and fluid dynamics, as well as educators looking for practical examples of pressure calculations in real-world scenarios.
pentazoid
During a hailstorm , hailstones with an average mass of 2 g and a speed 15m/s strike a window pane at a 45 degree angle. The area of the window is .5 m^2 and the hailstones hit it at a rate of 30 per second. What average presure do they exert on the window? How does this compare to the pressure of the atmosphere?
[tex]\overline{}[/tex]P=[tex]\overline{}[/tex]F/A=-m([tex]\Delta[/tex]vx/([tex]\Delta[/tex]t)/A
N/s=30 hailstones/sec
m=2 grams
[tex]\Delta[/tex]vx=vx,final-vx,initial=(-vx-vx)=-2vx
P=m(-2vx)/([tex]\Delta[/tex]t))*N/A=(2e-3 kg)(-2(15)(cos 45 degrees)(30))/(second)/(.5 m^2)
to compare the pressure of the hail stone to the pressure of the atmosphere, wouldn't I take the ratio of the pressure of the hailstone to the pressure of the atmosphere?
The pressure calculation looks ok to me. Sure, a ratio would be a good way to compare the two pressures.
  • · Replies 23 ·
  • · Replies 47 ·
