What Is the Stone’s Speed at 96,000 km From Earth?
  • Context: Undergrad
  • Thread starter Thread starter weltza
    Falling Orbit
The discussion revolves around calculating the speed of a stone released from rest at the Moon's orbit as it falls towards Earth, specifically when it is 96,000 km from the center of the Earth. The conversation includes various approaches to solving the problem, including energy conservation and orbital mechanics.
  • Homework-related
  • Adam proposes using the work done by Earth on the stone and subtracting the kinetic energy based on the stone's orbital velocity, but is uncertain about the influence of the Moon's gravity.
  • Another participant suggests considering the stone's motion as an elliptical orbit with high eccentricity, implying that Keplerian equations could simplify the problem.
  • There is a discussion about the nature of the ellipse being "pencil-thin" due to the stone's small mass compared to Earth, and whether changes in kinetic energy can be calculated from changes in potential energy.
  • A participant clarifies that the thinness of the ellipse is a result of the chosen parameters rather than inherent properties of the bodies involved.
  • Another participant elaborates on the eccentricity of the orbit, explaining the implications of different values of eccentricity and how they relate to the stone's motion.
  • One participant emphasizes that while Kepler's equations become singular at zero angular momentum, conservation of energy can be applied to find the stone's velocity without needing to determine the time of fall.
Participants express various approaches to the problem, with no consensus on a single method. There are competing views on whether to consider the Moon's gravity and how to apply orbital mechanics, indicating that the discussion remains unresolved.
Participants mention the complexity of the problem, including the need to sift through extensive material and the nuances of applying Kepler's equations in this context. There is also uncertainty about the assumptions regarding the stone's initial conditions and the influence of the Moon.
weltza
I have a bunch of ideas how to solve this problem, but I cannot figure out which one is right...
A stone is released from rest at the Moon’s orbit and falls towards the Earth. What is the stone’s speed when it is 96,000 km from the center of the Earth?
Thanks,
Adam
Astronomy news on Phys.org
What are your ideas?
well, I was thinking of using taking the work Earth does on the stone and subtracting the kenetic energy of the stone based on the orbital velocity. but, I'm not sure if the problem wants me to take into account the gravity of the moon.
also, I could use gravitational potential of Earth and again, use TE=KE+PE
I'm trying to sift through fifty pages of text to figure this out.
A way to think of these things is to pretend the stone is in orbit, but traveling by an ellipse with a huge eccentricity, a pencil-thin ellipse. Equipt with just Keplerian orbit equations, this should be an easy problem.
ok, maybe you could give me a little more guidance. This is my first week of astronomy.
Is the ellipse is pencil thin because the stone has such a small mass compared to earth? And can I then just find the change in KE based on the change in PE? Or am I still missing something?
I think what Helios was trying to say was that you should use the pencil-thin elipse as a good aproximation of falling straight down. So, the elipse is that thin only because you set it that way, not because any property of the bodies in question causes it to be. Use Kepler's equations to figure out the velocity of the rock at any point along its "orbit," which is almost stationary at aphelien and falls almost straight down.
by huge eccentricity do you mean just less than 1? because e=1 is a parabola and >1 is hyperbola. I am not quite sure what equation I should be using.
There are three different cases where e=1. One is a parabola (zero total energy, non-zero angular momentum). Another is a degenerate parabola (zero total energy, zero angular momentum). The third is a degenerate ellipse (negative total energy, zero angular momentum). Some jokingly call this case an "orthogonal orbit". The rock falling from at rest represents an example of this third case.
Think of it in terms of a limit. Suppose that instead of starting with zero velocity at the Moon's orbital distance, the rock starts with zero radial velocity and a tiny but non-zero tangential velocity. The rock will follow an elliptical orbit with apogee at the Moon's orbital distance. In the limit that that tangential velocity goes to zero, the eccentricity will go to one. As Kepler's equations become singular at this limit, you cannot use Kepler's equations directly. However, you can use Kepler's equations to solve the problem for any non-zero angular momentum. Take the limit of this solution as angular momentum goes to zero.
These machinations would have come in handy had you been asked to determine the time needed to fall from 384,400 km to 96,000 km. However, you were not asked that. You were just asked to determine the velocity. All that takes is conservation of energy considerations. Use the approach to which you alluded in post #3.
gotcha, thanks!
  • · Replies 16 ·
  • · Replies 18 ·
