Nonsingular perturbed identity matrix
  • Thread starter Thread starter Codezion
    Identity Matrix
The discussion revolves around the properties of a matrix defined as A = I + uv*, where u and v are vectors. The original poster is tasked with showing that the inverse of A can be expressed in a specific form, given that A is nonsingular.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants explore the implications of A being nonsingular and question the assumption that A is orthogonal. They discuss properties of matrix inverses and the correct application of matrix transpose rules.
Participants have provided guidance on the properties of orthogonal matrices and the correct application of matrix operations. There is an ongoing exploration of the implications of the derived expressions and the conditions under which the inverse holds.
There is a noted confusion regarding the definitions and properties of orthogonal matrices, as well as the implications of certain scalar values leading to singularity. The discussion includes attempts to clarify the relationship between the vectors involved and the resulting matrix properties.
Codezion
If A = I + uv*, where u and v are m vectors and A is known to be nonsingular, show that the inverse of A = I + [tex]\alpha[/tex]uv* where [tex]\alpha[/tex] is a scalar value
Since A is nonsingular, we know the rank of A is m.
Since both u and v are vectors of dimension m, we know that uv* is a square matrix
From the above statements, we conclude that A is an orthogonal matrix which imples:
A[tex]^{-1}[/tex]
= A [tex]^{*}[/tex]
= (I + uv*)*
= I + (uv*)*
= I + u*v
= I + [tex]\alpha[\tex], since u*v is a scalar value<br /> <br /> As you can see, I am arriving at the wrong conclusion. What am I missing? Thank you![/tex]
I note two problems:
(1) I have no idea how you conclude A should be orthogonal.
(2) (AB)* = B*A*
(1) - I think one of the definition of an Orthogonal matrix is a square matrix, whose columns are all linearly independent so that they make the basis for an m space. One of the properties of a nonsingular matrix is that it has the maximum rank (in this case m since it is a square matrix). These statements led me to conclude our matrix A is orthogonal!
(2) - That is a correct property...did I miss something?
You forgot a key word in that characterization: they have to make an orthonormal basis.
(Lemme switch to S and T instead of A and B, to eliminate confusion)
Yes. The property is (ST)*=T*S*, but you used it in your calculation as (ST)*=S*T*.
Wow! Thank you I missed that! I was assuming (AB)* = A*B* all along - even after I read your post! Thank you.
If A is not an orthogonal matrix, then I guess I am back to square one :(
Simple is often best, even if it's just to get ideas. Rather than looking for a clever argument, why not test directly whether or not this alledged inverse to A really is?
The matrices are inverses if (I+uv*)(I+alpha uv*)x=x for any vector x. Expand it out and try to figure out a value of alpha that will make that true.
Thank you! Figured it out :)
(I + uv*) (I + alpha uv*)x = x
(I + alpha Iuv* + Iuv* + alpha uv*uv*)x = x
v*u is a scalar and let it be beta
(I + alpha Iuv* + Iuv* + alpha beta uv*)x = x
[I + Iuv*(alpha + 1 + alpha beta)]x = x
this implies (alpha + 1 + alpha beta) = 0!
alpha = -1/(1+beta)!
Note that x was really just a placebo. You could have gone straight to the definition of inverse, and put an I on the right hand side, without any of the x's, and done exactly the same thing.
I like the expression (placebo). Yup, thanks Hurkyl. Thanks so much.
If beta = -1 (which would imply A is singular), what would the nullspace of A be? I got only as far as writing the equation as:
(I+uv*)x = 0
x + uv*x = 0...
Do you have any suggestions?
Well, if it's going to be at all easy to figure out, it's probably going to be some expression involving u or v. (I+uv*)x = 0 is a linear equation, so I would start by plugging in a few things, and see if I can combine them to make 0.
(I+uv*)x = 0
x + uv*x = 0...
Sure you don't want to take a crack at this without a hint? It's pretty easy. Remember beta=v*u=(-1).
Thanks a lot for your help guys.
Dick, I think it could be the pressure:), but I still cannot see it. Here is what I did
v*x is some constant beta,
x + uv*x = x + beta u
=> x = -beta u
Therefore, I concluded x is a scalar multiple of u.
This is what I came up with, but it looks dodgy because I somewhat defined beta with x itself..?
OH! I see it now :) if x = u, then
x + uv*x = u + uv*u = u + -u = 0
You are right Dick, it was easy! :)
Thanks a bunch!
I think you confused yourself, because you now have two variables named beta! One of them was the inner product of u with v, and the other is the inner product of x with v.
But no matter; you can test directly if u is a right null-vector or not (I now see you've done that). Of course, you'll have to clean up your proof if you want to claim that the right nullspace is one-dimensional.
(p.s. as an alternative, there is a rank-counting argument that tells you that A cannot be less than n-1 dimensional. Can you see it? Hint: it might be easier to think instead of the equation I = A - uv*)
  • · Replies 26 ·
