How long will it take to reach 3km?
  • Thread starter Thread starter speedy46
    Time
The discussion revolves around a physics homework problem involving a jet aircraft climbing vertically. Participants analyze the forces acting on the aircraft, calculate acceleration, and attempt to determine the time taken to reach a height of 3 km, using relevant equations of motion.
  • Homework-related
  • One participant states the aircraft climbs at an attitude of 90 degrees to the horizontal, seeking clarification on whether this is correct.
  • Another participant emphasizes the need to sum the forces acting on the aircraft to determine acceleration, suggesting a diagram may help clarify the forces involved.
  • A participant expresses intent to work through the problem and share their calculations for feedback.
  • Concerns are raised about the use of cosine in calculations, the distinction between mass and force, and the need for consistent units throughout the problem.
  • One participant calculates net force and acceleration, arriving at a time of approximately 63.99 seconds to reach 3 km, but another points out potential errors in their calculations.
  • Corrections are suggested regarding the arithmetic and the application of equations, with a focus on ensuring clarity and accuracy in the problem-solving process.
  • A later reply confirms the final velocity calculation but points out a notation error in the equation used.
Participants express various levels of confusion and disagreement regarding the calculations and the application of physics principles. There is no consensus on the correctness of the initial calculations, and multiple viewpoints on the approach to solving the problem are presented.
Participants note inconsistencies in units and arithmetic, and there are unresolved issues regarding the correct application of equations and the interpretation of forces acting on the aircraft.
speedy46
A jet aircraft climbs in a straight line at an attitudeof 90 degrees to the hozizontal. The jet thrust amounts to 90kN, the mass of the aircraftis 8 tonne and the average air resistance mounts to 11kN. Calculate the time taken to reach a height of 3 km if the speed at the start of the climb is 160Km/h.
u= 160km/hr = 44.4 m/s
a= to be calculated
s= 3000m
t=
S=u*t+ 1/2 at^2
F= m times a
vertical acceleration force
79 cos 60 - 8000kg
F=ma
a=f / m
0 = (1/2a) t^2 + (u) t + s
0 = 2.435t^2 + 138.56 t - 3000
am confused.
Hi speedy. I'm a bit confused too... you have that the aircraft is climbing at an attitude of 90 degrees to the horizontal. That tells me it's going straight up. Is that right? Or is the 90 degrees a typo?
Regardless of if it's a typo or not, it seems like you have the right equations. Just have to solve them. The thing you're trying to determine is acceleration. To do that, sum the forces in the direction of motion of the aircraft first. What forces are pushing back or resisting the forward motion of the aircraft? What forces are pushing the aircraft forward or tending to accelerate the aircraft? Try drawing a picture of the aircraft with forces acting on it if you're still confused, then try to resolve what those forces are.
Those forces are resisted by the mass of the aircraft, so you should be able to solve the acceleration by summing the forces and then dividing by the mass of the aircraft.
Once you determine the acceleration, stick that into your equation:
S=u*t+ 1/2 at^2
And solve for time.
Nope the 90 degrees is not a typo
I will be am going to have a go then post my workings out to see if there correct
Then why did you multiply by cos(60 deg)? Also, mass is not force; you cannot subtract mass from force. Plus your units are currently inconsistent. Convert all numeric values to consistent units.
Net force = 9000 - 89000 = 600N
F=ma
a=600/800 = 0.075m/s^2
V^2=U^2+as
V^2= (44.44^2) + (2*0.075*300)
V= 49.24m/s
t=V-U/a = 49.24 - 44.44 / 0.075 = 63.99s
Could you please tell me if this is right
Thanks In advance
9000-89000 is not 600
Looks like you typed something wrong, but it's not obvious where the mistake is.
600/800 is not 0.075.
It looks like you meant either 600/8000, or you meant 0.75
Please try to proofread your posts. If you see little math mistakes like these, you can still edit it and correct the simple stuff. It is difficult to follow your thought process if you keep typing in the wrong numbers.
It's just a matter of being more careful. Then we can help.
I have changed my lay out hope this is better for you to follow:-
Conversions.
8000 × 9.8 = 78400N
160Km/h = 44.44m/s
Equations Needed.
F = m × a
S = u × t + 0.5 × a × t2
The solution.
Net Force = Jet thrust – (air resistance + weight of plane)
Net force = 90000N – (11000N + 78400) = 600N
Working out the acceleration.
F = m × a
a = f ÷ m
= 600 ÷ 8000 = 0.075 m/s2
Working out the time.
V2 = u + 2 × a × s
V2 = (44.442) + (2 × 0.075 × 3000)
V2 = 49.24m/s
v = u + a × t
t = v – u ÷ a
t = 49.24 – 44.44 ÷ 0.075
t = 63.99s
Thanks in advance
That answer looks right.
Things got a little sloppy here, but you probably just copied down things differently from where you worked this out on paper:
speedy46 said:
V2 = u + 2 × a × s
V2 = 49.24m/s
Should be V^2 = u^2 + 2×a×s,
but V=49.24 m/s is correct.
  • · Replies 21 ·
