Lorentz transform and muon half-life, Help, please
The discussion revolves around the application of the Lorentz transformation in the context of time dilation experienced by muons traveling at relativistic speeds, specifically at 0.98 times the speed of light. Participants explore the implications of time dilation, the proper and improper time measurements, and the mathematical formulations involved in these transformations.
  • One participant expresses confusion about how time dilation is calculated using the Lorentz transform, questioning the treatment of velocity and space in the equations.
  • Another participant clarifies that time dilation is not calculated "in the moving system" and emphasizes that if the velocity were zero, there would be no time dilation.
  • A different participant explains the concept of transforming to a spacetime frame where the muon is at rest, noting the comparison between improper time and proper time.
  • Concerns are raised about the interpretation of time dilation, with one participant stating that it is only observed when a moving clock is compared to a stationary one.
  • Further clarification is provided on the derivation of the time dilation formula using the Lorentz transformation, emphasizing the conditions under which the formula applies.
  • Another participant discusses the spacetime interval and its invariance across different frames, suggesting that the derivation of the interval transforms does not necessarily rely on Einstein's second postulate regarding the constancy of light speed.
Participants exhibit a mix of agreement and disagreement regarding the interpretation of time dilation and the application of the Lorentz transformation. Some participants clarify points raised by others, but no consensus is reached on the implications of the equations or the necessity of certain postulates.
There are unresolved aspects regarding the assumptions made in the calculations, particularly concerning the treatment of velocity in the context of time dilation and the implications of the spacetime interval across different frames.
robert Ihnot
I am new to this matter, but I was reading a problem about how as the muon travels at .98c, that it's half life is increased by an approximate factor of 5.
What I have trouble with is when using the Lorentz transform, why time dilation is calculated in the moving system at the same X and V so that the term VX/C^2 goes out, giving us a simple form, when it would seem that if the muon was going at .98 speed of light that it would move through space.
Thus, how do you keep these things straight, and get these simple results? Thank you, bob
Perhaps I do not understand the question. Yes, of course, if a muon is traveling at .98 the speed of light it is would move through space- very fast! Time dilation is NOT calculated "in the moving system" since, if it were, v would be 0 and there would be no time dilation. if v= .98 c then v2/c2= .982= .9604 so 1/√(1- v2/c2)= 5 approximately. What "simple result" are you talking about?
You are transforming to a spacetime frame of reference in which the muon is at rest. This means you are comparing improper time (a physical moving clock) to proper time (a stationary clock). In that reference frame, X' remains constant.
I meant the Lorentz transorm
We have the form t' = (t-vx/c^2)/sqrt(1-(v/c)^2), yet the form simplifies to
T' = T/(sqrt(1-(v/c)^2) so that we have dropped some terms, but now I understand that time dilation requires that velocity be 0, as you have kindly explained. Thank you!
Careful with those clocks
I'm not sure what you mean by saying that time dilation "requires that velocity be 0". It is only when a moving clock is observed that "time dilation" is evident. If the clock isn't moving (with respect to the observer) there is no time dilation (or any other special relativistic effects).
It will be easier to understand how the "time dilation" formula is derived if you express the Lorentz transformation like this:
Δt' = (Δt-vΔx/c^2)/sqrt(1-(v/c)^2)
Now, if you have a clock in the unprimed frame that measures a time span of Δt, how much time will the primed system (moving with speed v) observe to have elapsed (this is Δt')? Use the LT to find out. In the unprimed system the clock just sits there, so Δx = 0. So...
Δt' = (Δt)/sqrt(1-(v/c)^2)
That's the so-called time-dilation formula.
When two frames are in uniform relative motion, the spacetime interval in one frame is always equal to the spacetime interval in the other - and when the interval is calculated in one frame according to a clock which measures proper time in that frame, the end points of the interval are subtractive so the vx/c^2 factor disappears - one implication of this result is that is that the controversial postulate of one way light velocity is not essential to the ultimate transform of the spacetime interval from one frame to the other, that is, one can derive the interval transforms referred to in the author's original post w/o Einstein's second postulate.
  • · Replies 18 ·
  • · Replies 30 ·
  • · Replies 84 ·
