X and x' in two coordinate relativistic systems
The discussion centers on the application of Lorentz transformations between two coordinate systems, S-OXYZ and S'-O'X'Y'Z', with S' moving at velocity v away from S. The transformation equations are explored, particularly at t=0, where the relationship x = x'γ is established. Participants clarify the need for the general transformation x' = γ(x - vt) and address the confusion surrounding the derivation of γ² = 1. The conversation emphasizes the importance of correctly applying the Lorentz transformations to avoid misinterpretations of the coordinates.
  • Understanding of Lorentz transformations in special relativity
  • Familiarity with the concept of relativistic velocity (v) and the Lorentz factor (γ)
  • Basic knowledge of coordinate systems in physics
  • Ability to manipulate algebraic equations involving square roots and variables
  • Study the derivation of Lorentz transformations in detail
  • Learn about the implications of time dilation and length contraction in special relativity
  • Explore the concept of simultaneity in different inertial frames
  • Investigate the application of Lorentz transformations in practical physics problems
This discussion is beneficial for physics students, educators, and anyone interested in understanding the principles of special relativity and the mathematical framework of Lorentz transformations.
C_Ovidiu
let's say we have two coordinate systems ( S-OXYZ and S'-O'X'Y'Z') , S' moving with velocity v away from S . At t=0 O=O'.
According to Lorentz' transformations we have :
At t=0 x in as a function of x' :
[tex]x=\frac{x'}{\sqrt{1-\beta^2}}=x'\gamma[/tex]
Now, say I know x(I just found it above) , and I want to find x'
[tex]x'=x\gamma=x'\gamma^2=>\gamma^2=1[/tex]
Where does this come from and what have I missed ?
Thank you !
Why are you just looking at cases where t=0? The general transformation would be [tex]x' = \gamma (x - vt)[/tex], so if t=0 then you do have [tex]x' = \gamma x[/tex] (you seem to have reversed x and x' though, unless you meant to write t'=0).
I agree with [tex]x' = x \gamma[/tex] in the case of t=0, but where are you getting [tex]x \gamma = x' \gamma^2[/tex]? Are you taking the reverse Lorentz transform [tex]x = \gamma (x' + vt')[/tex] and setting t'=0 as well, thus getting [tex]x = \gamma x'[/tex]? The problem is that if you set both t=0 and t'=0, the only coordinates where both time coordinates are 0 are (x=0, t=0) and (x'=0, t'=0), so obviously if x'=0 then you can have [tex]x' = x' \gamma^2[/tex] even when [tex]\gamma[/tex] is not 0.
Tnx.
  • · Replies 54 ·
  • · Replies 22 ·
  • · Replies 24 ·
