Maxwell's Demon: An Energy Conversion Experiment
The forum discussion centers on an innovative energy conversion experiment utilizing a specialized electronic tube with two Ag-O-Cs cathodes, A and B, which exchange thermal electrons under a magnetic field, generating a potential difference. The experiment achieved a maximum current of 8.0×10-13A, demonstrating a novel approach to energy conversion that challenges traditional interpretations of the Second Law of Thermodynamics. Participants debated the implications of the low current output, the energy costs associated with maintaining the magnetic field, and the potential for scaling the experiment with additional cathodes or alternative materials.
  • Understanding of Maxwell's Demon and its implications in thermodynamics
  • Familiarity with electronic components, specifically Ag-O-Cs cathodes
  • Knowledge of magnetic fields and their effects on electron flow
  • Basic principles of energy conversion and thermodynamics
  • Research the properties and applications of Ag-O-Cs cathodes in energy conversion
  • Explore advancements in low work function materials for improved energy efficiency
  • Study the principles of electromagnetic induction and its historical context
  • Investigate potential methods for scaling up the energy output of similar experiments
Researchers in the fields of physics and engineering, energy conversion specialists, and anyone interested in the practical applications of thermodynamic principles and innovative energy solutions.
xyfu
Maxwell’s Demon
An Energy Conversion Experiment in Contradiction to the Second Law​
We have performed successfully an experiment of energy conversion of a totally new type. Please see the attachment figures. The experiment relates to a special electronic tube, which has two similar and parallel Ag-O-Cs cathodes, A and B, lying on the surface of an insulated base. A and B are very close but well insulated each other, and they eject thermal electrons at room temperature ceaselessly. Over the narrow interval between A and B, the two cathodes may exchange thermal electrons. As the flow of electrons from A to B equals the one from B to A, no net accumulation of electrons occurs in either side. If we now bring a uniform magnetic field to bear on the electronic tube, the thermal electrons will fly only from one cathode to the other, resulting in an electric potential difference between A and B. The potential difference slows down the follow-up electrons as they fly passing over the interval. The electrons are cold down (slightly), causing the whole tube to cold down, too, (much more slightly). Hence the tube will extract heat from exterior to compensate its change in temperature. Accompanied by these processes, there is simultaneously a conversion of energy from the heat extracted from the surrounding air to electric energy of a direct current supplying to an outside load. The maximum current got in the present experiment is 8.0×10-13A, corresponding to a single way flow of electrons from one cathode to the other at a rate of five million electrons a second. Compared to Maxwell’s original idea of an intellectual being, which was supposed capable to interfere or control the molecules’ random motions in a gas, the magnetic field here is really a very skillful demon.
For more details, please refer to our paper Realization of Maxwell’s Demon. It is on the webpage of http://www.arxiv.org/list/physics/0311?100 , No. physics/0311104. And you may download the paper directly from the web address http://www.arxiv.org/pdf/physics/0311104. We also enclose the paper as one of the attachment. Please check.
xyfu
06/01/04
Pretty interesting paper, well presented.
1. I did notice the current produced was VERY low, and at the bottom end of the range for the Chinese-manufactured test equipment:
"The current measuring range of ZC43 (produced by Shanghai Sixth Electric Meter Factory) is from 1 x 10-5A to 1 x 10-14A."
2. You would have to think that the output current (8.0×10-13A) is less than what it would take to maintain a magnetic field of equivalent strength to the magnets used in the experiment. I mean, the magnets came from somewhere and it took energy to create them. That isn't free... is it?
I find it interesting too. To help me understand, I thought of the following analogy. Holding a pool of liquid like water or gasoline in your hand, you notice it evaporates: molecules 'jump' into the atmosphere and do not return. In consequence, the liquid cools. So in this experiment, electrons 'evaporate' and the cathode emitting them is cooled. No mystery there. The real trick is of course to "close" the system. Find a way to get the water molecules back into the pool that costs no energy. THen you would have a free fridge. Of course that is impossible. In the experiment discussed in the paper, electrons travel through an ammeter, completing the circuit. This circuit would be "closed" if the ammeter were entirely passive. But I doubt that is the case. I guess it needs electrical power to operate: Power that is absolutely humongous compared with the tiny voltage and current in the circuit. So for me the jury is out until I know much more about how the meter operates.
Did you do a control (i.e null) experiment? For instance, have exactly the same set up except with cathodes which do not produce any thermal electrons at room temperature. Also, you could try putting in a barrier between the cathodes to catch the electrons.
Also, I'm afraid that it is impossible for anyone to make any sense of your measurements as there are no indications of error bars. (you may think this pedantic but it is a very important issue)
Matt
Reply to DrChinese
Quote from DrChinese
Reply to DrChinese
Thank you for your comments. I think the magnets are free.
When I am going to do the experiment, I can borrow some magnets from one of my friends. After the experiment, I return the magnets to him and the magnets can be not changed at all. So, the magnets are free.
In an ideal Carnot's cycle, a cylinder and a piston are used. Are the cylinder and the piston free? If we want to create a new cylinder and a new piston, we must spend some energy and so on. But it doesn't matter. You can borrow a cylinder and a piston from one of your friends before you start to carry out the cycle, and return them to him after you finished the experiment. They can keep unchanged totally. So we say the cylinder and the piston are free.
Permanent Magnets are wdely used today in electric generators and electric moters, especially in those of powers range from several watts to hundreds of watts. These magnets can be used for one year, five years, ten years , twenty years, and even longer. Provided they are used carefully and not hurted accidently, they will be at last as fine as they were before they are used. There is no change at all in these magnets. So I think actually it is well accepted that magnets used in such ways are totally free.
Would you agree my arguments?
Reply to DrChinese
I am not certain. I agree it comes down to returning the magnet to your friend (in the analogy) in the same condition you received it.
So let's ask: if you pull 8x10^-13A current at .08 volts out of the generator for 1.78 million years, you would get a kilowatt-hour. Would the magnet be in the same condition at that time? I think over that period it would be clear that total entropy obeys the 2nd law.
But I do think the concept is ingenious even if a violation of the second law has not occurred.
Doesn't this experiment effectively measure the energy needed to make the demon's decisions - by measuring the decreased field strength of the magnets over time, and dividing by the total number of electrons over that interval?
My understanding of Maxwell's problem is that the paradox is resolved by the energy contained in structured information; as opposed to random data that contains no useful information hence no structure or order. The proof offered in one lecture was that a machine can be built that does useful work by reading structured information, but that can't do useful work by reading random data. From this, an information/energy equivalency is suggested.
The energy of the field in a magnet is restored as the object repelled or attracted reverses its motion. In the case of permanent magnet DC motors, the energy comes completely from the electricity supplied. No energy transfer from the magnets to the system is unidirectional. The system is always restored by means of momentum and electrical power losses. I believe that the back EMF is precisely this potential for work.
The fact that we can't make a permanent magnet only motor is the proof. No free energy.
xyfu said:
Reply to DrChinese
I love this answer!
Here are Maxwell's original words describing what later came to the called "Maxwell's Demon":
James Clerk Maxwell
Address:http://webserver.lemoyne.edu/faculty/giunta/demon.html
Quote (from DrChinese et al.):
The maximum current obtained in the experiment was only 8.0×10-13A, and the voltage was only 0.08V. The output power was extremely low.
The output current and voltage are really extremely low, but it means a new beginning, as an old restriction is broken here. Things can then be developed tremendously.
In our present test tube FX1, there is only one pair of Ag-O-Cs cathodes. Actually we can settle several pairs of such cathodes in a single tube, and connect them in series to get greater electric motive force, or connect them in parallel to get greater current. If thousands or millions of such Ag-O-Cs pairs are settled on the surfaces of some quartz plates in a single tube, and connected in some proper way, a much greater power will be possible.
Efforts should also be made to find new cathode materials with work functions lower than Ag-O-Cs. The work function of present Ag-O-Cs cathodes is about 0.7 to 0.9 eV. Can we find some new materials whose work functions are only 0.1 to 0.2 eV? There is no theoretical limitation to lower work function. The output power of a single tube may be possible to increase tremendously in this way.
On the other hand, we can replace Ag-O-Cs cathodes to oxide cathodes (Ba and Ca oxide cathodes, etc), which work at a temperature of about 800oC. Such a tube can extract heat from a high temperature heat reservoir (a furnace or a nuclear reaction apparatus for example) and convert the heat into electric power, in large scales.
When Faraday discovered electromagnetic induction in 1831, he could get only very weak and instantaneous current in his coils. He then made efforts of years to design or invent electric generators that could produce a strong and continuous current. What he succeeded finally was only something that can only be regarded today as poor child toys. Nevertheless, these poor toys are pioneers or pre-prototypes of the modern powerful generators that might posses a power of one million kilowatts each set.
What we are doing now is trying to make “died energy” to revive again. Such a task is certainly much difficult than Faraday’s task of converting mechanical work into electric energy. There is nothing strange or surprising that the road in front of us is much longer than the road in front of Faraday.
But you don't find magnets on that road, either. The magnet effectively powers the process, almost like a type of battery. Uranium contains an energy source too, but when you extract energy from it you don't violate the 2nd law. My point being that you assume that the magnet is not changed as work as extracted from it. I believe that the energy output (if any) is offset by matching changes in the magnet (if any).
It takes energy to create a magnet (an ordered system). But there is no way to measure the strength of a magnet to a sufficient degree of precision to detect the subtle changes in the magnet. If you could, it would show that the magnet loses strength exactly equal to the energy output. Since the net gain is zero (or less than zero), the process obeys the 2nd law.
That doesn't mean that the physical process you describe is worthless. I simply doubt that the 2nd law of thermodynamics is violated.
The energy here is thermal. Not elecromagnetic.
No, the magnet is not "depleted".
It takes work, some expenditure of energy, to magnetize a magnet, but don't confuse a magnet with a battery, or a capacitor. The magnetic field is an inert tool that can be used to knock electrons around. It loses nothing in doing this. Magnets "wear out" because the little domains eventually slip out of alignment. No energy has been lost. A brief second in a strong magnetic field and it is good as new.
Good magnets are those that have the most friction between the domains. These last longer. It is a matter of the material used, not the energy required to magnetize them.
A magnet isn't "used up" by being employed an more than we are wearing gravity out by using it all day to stay stuck to the earth.
The device described here is running off of thermal energy from the surroundings.
zoobyshoe said:
1. A magnet isn't "used up" by being employed an more than we are wearing gravity out by using it all day to stay stuck to the earth.
2. The device described here is running off of thermal energy from the surroundings.
1. I am not saying a magnet is a battery and my analogy in that regard was not a good one. What you are saying makes good sense. But I am not sure I fully agree with your comparison of the magnet and gravity in one sense. The magnet is an artificially ordered system and it takes energy to create it. It wouldn't surprise me if a way was found to utilize that order. Since this experimenter states that the current produced is some function of the magnet, it would seem a good place to examine when someone claims the 2nd law is being violated. (My confidence in the 2nd law is very high.)
2. I am not sure what is creating the reported current in the described system, assuming there is one (which is probably a big if). Are you saying it is coming from the surrounding environment? I guess there could be a small temperature gradient in the apparatus which is not readily apparent (since the output is so low). If so, I wonder how that is converted to provide power.
In ferromagnets, the minimum energy is where neighbouring spins align. However, the maximum magnetic field energy of a macroscopic ferromagnet is at maximum field, when all spins are aligned. The competition between these two effects is what results in domains. So a soft ferromagnet like mild steel may have no magnetic field because there are many small domains whose fields cancel each other. In a "hard" ferromagnet, the spins do not change direction easily. So you can magnetize a chunk and it stays. (Good thing too, in the case of hard drives.) However, over time, even hard ferromagnets lose their field, because of the tendency toward randomization and minimum energy.
I find DrChinese's suggestion interesting. Remember that the released electrons, in looping from one place to another, create their own magnetic field, which will act back on the permanent magnet and tend to demagnetize it.
I understand your logic. Guided by Occam's Razor, though, we should approach all claims of violation of the "laws" of thermodynamics and motion as misunderstandings by the claimant. I have never encountered a situation where the law wasn't simply misunderstood, or where what was happening in a device hadn't just been misunderstood.
The magnets here function analagously to a diode, taking a back and forth exchange of electrons between the electrodes and converting the motion to exclusive one way travel.
The electrons, you will notice, he describes as "thermal" electrons. I take this to mean they are exited to jump off the electrodes by, or by something akin to, the photoelecric effect. Notice the special material of the electrodes silver, oygen, carbon. My guess is that this compound is more sensitive than most to having electrons exited off of it in this way. Silver puts me in mind of the fact that photo-sensitive silver nitrate is used in photography.
However, the real evidence the effect is thermally driven come from his explanation of how the system tend to cool, and then to suck heat in from the environment to try to maintain a mean temperature. That's pretty explicit. That is where the energy is going into the system. It's not Maxwell's Demon. It's a solid state bobbing bird.
This is the case to be sure. Using a magnet puts a strain on the domains, and encourages them to go out of alignment. I didn't bring this up before because I didn't want this effect to be misunderstood as "using up the magnets energy".
How quickly a magnet's domains go out of alignment depends on how good the friction between the domains is. It is completely unrelated to how many joules it took to magnetize the magnet.
The force of a magnetic field comes from the electric fields of the electrons you described. The electrons and their fields don't get "used up" or "discharged" in any way when you employ a magnet to do work. Nor is the amount of work you can do with it before it goes out of alignment related in any important way to the energy it took to align the domains.
The newer (post WWII) ferrimagnetic magnets are just about immortal compared to the old hard-steel ones, so the wearing out of magnets is not a serious issue in all normal applications.
Sorry if this has been brought up already in this thread, but it seems like the original experiment is just a new version of a thermoelectric conversion. The magnet is helping to alter the paths of the thermal electrons so that there is a slight preference for the landing electrode. The effect could probably be maximized once the effect of the magnet was simulated, but the efficiency of the conversion from heat to electrical power probably would not exceed the traditional thermoelectric conversion efficiency, which is not considered high enough to violate the arguments against Maxwell's Demon.
Some thermoelectric background if anyone is interested:
http://www.nanothermel.org/public_main.htm
Neat forums, BTW. -Mike-
Exactly, regarding the magnet.
I am not certain what is prompting the electrons to fly off the electrodes in the first place, though. Their materal is very specific. I lean much more toward photoelectric as an explanation for these leaping leptons than thermoelectric.
If it does work, it loses energy. Knocking electrons around is doing work.
This is not the same. By staying stuck to the Earth we exist at a constant potential. This acceleration thus force acts over no distance, ie the field does no work on us. In the case of changing the direction of an electron, work is done and energy must be lost by the magnet; or the error is small enough to be within limits of uncertainty.
“The second law of thermodynamics holds, I think, the supreme position among the laws of nature. If someone points out to you that your pet theory of the Universe is in disagreement with Maxwell’s equations - then so much the worse for Maxwell’s equations. If it is found to be contradicted by observation - well, those experimentalists do bungle things up sometimes. but if your theory is found to be against the second law of thermodynamics I can give you no hope; there is nothing to do but to collapse in deepest humiliation.”
-------- Arthur S. Eddington (British Astrophysicist, 1882-1944) in The nature of the Physical World (1928)
Thing is, it isn't "knocking the electrons around". It is existing there, static, and the electrons are doing all the moving, bouncing off of it. Like a spring, it contributes no more energy to the electron than the electron brought to the impact. The electron gains no energy from this encounter, just a change of direction.
If you bounce a ball off a wall, is the wall doing work? Perhaps it is by the strict deinition, I don't know if it is or isn't. My main point is that, when you generate electricity with a magnet and a coil, you aren't harvesting any of the electricity you get from the magnet. I am trying to dispell this notion that magnets wear out because a fictional store of energy, given to them when they are magnetized, is somehow being slowly harvested over time.
The point of my analogy to gravity, of course, is that we don't wear gravity out. I said "stuck to the earth" but of course, you could stand somewhere for the rest of your life picking a brick up and dropping it without depleting the gravity one bit. It is an analogy, and like all analogies it comes to a point where it no longer applies. If you find an analogy that applies no matter how you look at it, you're really not making an analogy, you have discovered twins.
I have a ferromagnet with alligned spin domains. An electron is making some dynamical motion due to the Lorentz force from the magnetic field of the ferromagnet.
In this situation (i.e. devoid of direct physical contact, and no wild temperature fluctuation above the Curie temperature), the ONLY way for the magnetic field to be weaker is for there to be a spin flip within the WHOLE magnetic domains. This is the only way for the "energy" of the ferromagnet+magnetic field system to be weaker.
Thus, can you tell me what is the mechanism, in principle, that would cause such massive spin flips?
I would also like to point out that SQUIDS can measure magnetic flux at unbelievable accuracy - on the order of the quantum flux (which is how we could detect those fractional quantum hall effect). If such a flip occurs, not only for each magnetic domains, but even for a SINGLE spin, we can detect that.
Zz.
I think the low output leaves a lot of open doors on this experiment. I understand the experimenter's point about hooking it up in parallel/series to boost the output. But I think we are all aware that changes nothing about the fundamental underlying processes. What doesn't work for one, also won't work for many.
Clearly, if there is energy out, it is coming from somewhere, per SLOT. I think we have now identified clearly 2 critical issues: a) is there a real output, given its low magnitude? b) is the system truly closed, given the low magnitude of the output?
Again, even without a violation of SLOT, there might be some application somewhere out of this. But I predict there will be no free lunch.
My first reaction was "Maybe they can, but how do we communicate with them? Tentacle sign language?" Of course google cleared this up:
superconducting quantum interference device
Address:http://whatis.techtarget.com/definition/0,,sid9_gci816722,00.html
LOL ! I had the same first reaction as I was reading the sentence, but luckily figured it out and put in context in a couple of seconds. Even worse for me is that I ride a sportbike, and Squid has a number of other meanings in that context. Too funny.
Precisely. Any electron emitted at whatever T returns to the cathode by any number of routes; the same number biased by the magnet toward B on emission from A will be biased toward A on their returns following emission from B.
Never has been, ain't, and never will be.
xyfu said:
Maxwell’s Demon
xyfu
06/01/04
Left this link for a while, time to intervene?
I recall this paper when it appeared on Pre-print, and dealt with some issue's on another forum?
I am sure the audience knows about :http://www.sp.uconn.edu/~terry/images/anim/ETS.html
and it is evident that your initial setup allows for some 'mind-bending' thinking to try and defeat the great demons!
How do you measure the reduced 'electron-value' from electrons that have been re-cycled from the surrounding atmosphere?..its a pretty big pool in which one has to produce a sure-fire limit with respect to an electron that has transported (leaked) into the experimental structure? I quote:
In the above process, the electronic tube extracts heat from the air and all of the heat is converted into electric energy, without producing any other effects. We hold that the process is in contradiction to Kelvin’s statement of the second law of thermodynamics /quote.
If this be true then Global Warming is the least of our problems, one can use your experiment to reduce the whole atmosphere's temperature by a significant amount just by activating the above FX1 experiment. I can see a time when some countries adapt this novel experiment and start 'dropping' weapons of 'HEAT-DESTRUCTION'.
Its quite evident that while a Blackhole removes light from surrounding space, you have tried to make a comparable working model of a 'Heat-Sink/Hole'.
Are your peers you thank in your paper bio-chemists by any chance?:
http://www.wiley.com/legacy/college...ons/electron_transport/electron_transport.htm
Well, if we can somehow neglect the counter intuitive perpetuum mobile neck hairs ruffling, :) it seems that our future vacuum cleaners will be powered by our airco's
I don't think anyone has suggested this possibility yet.
For the 2nd Law to hold with arbitrary precision, the energy in the system on which it puts restrictions must be totally thermal. All of the motion of its constituent particles must be random. This is true in the bulk but not necessarily at the surface of a solid object. The velocities of electrons emitted from the cathode in this experiment have a non-random component in the vertical direction; they're all going up. Their emission cools the cathode slightly, allowing it to absorb more energy from the slightly warmer ambient. And so on.
I may be kicking myself in a few minutes when somebody shows me how absurd this is (it's not everday you get to say the 2nd Law only works up to a point!). But everyone else is sticking their necks out with incomplete (but interesting) ideas. So for now, this is mine.
  • · Replies 28 ·
  • · Replies 28 ·
