The discussion revolves around the calculation of gravitational strength for a single body, exploring the relevant equations and concepts in both classical and Newtonian gravity. Participants inquire about the specifics of measuring gravitational force and the implications of mass distribution.
- Exploratory
- Technical explanation
- Conceptual clarification
- Debate/contested
- One participant asks for the equation to calculate the gravity of a single body.
- Another participant provides the equation for gravitational field strength as GM/r, noting its complexity in general relativity.
- A question is raised about whether 'r' is measured from the center of the object and if gravity is stronger closer to the center of the Earth.
- It is mentioned that Newton's gravity allows for treating an object's mass as if located at the center, regardless of shape or distribution, implying that a hollow Earth would not affect gravitational calculations.
- One participant points out that at the center of an object, the value of 'r' equals zero.
- Another participant clarifies that while mass can be treated as concentrated at the center in Newtonian gravity, this is only valid outside the body, and gravitational force decreases to zero when approaching the center.
- Inquiries are made about equations that reflect the gravitational behavior inside a spherical mass distribution.
- Equations are proposed for gravitational force outside and inside a uniform spherical mass distribution, indicating different behaviors based on the radius.
Participants generally agree on the basic principles of Newtonian gravity, but there are differing views on the implications of mass distribution and the behavior of gravity as one approaches the center of a mass. The discussion remains unresolved regarding the specific equations and their applications.
Participants express uncertainty about the assumptions underlying the equations and the conditions under which they apply, particularly regarding the uniformity of mass distribution and the validity of certain gravitational treatments.
