| Thread Closed |
Pendulum experiment |
Share Thread | Thread Tools |
| Jan20-09, 06:50 PM | #1 |
Pendulum experiment
Hi I'm supposed to come up with a design for a pendulum experiment. I have most of the design figured out but in regards to measuring the oscillation I don't know how to do it accurately aside from using a stopwatch to measure the oscillation(in which case the period would have to be really long). Also, with the pendulum experiment I was thinking of doing a coupled pendulum experiment as well or would it be too difficult. Thanks, btw, I'm in grade 12 I'm doing this as part of my Physics Experiment project.
| PhysOrg.com |
physics news on PhysOrg.com >> Promising doped zirconia >> New X-ray method shows how frog embryos could help thwart disease >> Bringing life into focus |
| Jan20-09, 07:08 PM | #2 |
Recognitions:
Time lots of periods (say 30 to 100) with your stopwatch. Get the duration of one period by dividing by the total number of periods.
| Jan20-09, 07:32 PM | #3 |
Okay that would make sense but is there another alternative because if I were to do that with the coupled Pendulum experiment I honestly don't know how I would go about doing it.
| Jan20-09, 09:32 PM | #4 |
Recognitions:
Pendulum experiment
http://www.theorphys.science.ru.nl/p...endul-en.shtml
I'm not sure this will work, just guessing. Anyway, it seems that if you let one pendulum go with the other at rest, the other pendulum will also oscillate, and the amplitude of its oscillations will also oscillate (ie. its amplitude will get bigger then smaller then bigger, let's call this this the "envelope"). You could time the periods of the pendula separately, and also time the period(s) of the envelope (seeing where it goes to zero is probably easier than seeing where it becomes largest). From all these periods you can get their frequencies. Apparently the frequency of the envelope is related to the difference in frequencies of the individual pendula. |
| Jan20-09, 10:35 PM | #5 |
| Jan21-09, 01:09 AM | #6 |
Recognitions:
Yes, the periods of 4 different things (and 10 - 30 periods of each thing to get a good estimate). Maybe you don't have to set it up with a spring. fredwittel's setup http://www.youtube.com/watch?v=RoSYKPTdlxs seems to behave similarly to the blue and red traces in http://www.theorphys.science.ru.nl/p...endul-en.shtml. These are just my guesses.
| Thread Closed |
| Thread Tools | |
Similar Threads for: Pendulum experiment
| Acceleration due to gravity using a compound pendulum experiment | Introductory Physics Homework | 3 | ||
| Air resistance in pendulum experiment | Classical Physics | 8 | ||
| i need answer regarding his experiment...a single pendulum | Introductory Physics Homework | 1 | ||
| Error in Simple Pendulum experiment | Introductory Physics Homework | 5 | ||
| Bifilar Pendulum experiment | Introductory Physics Homework | 2 | ||
