| Thread Closed |
Static particle with tension |
Share Thread | Thread Tools |
| Jan21-09, 03:26 PM | #1 |
An aerialist is walking a wire of length 8 meters. He is being pulled from the edge with a rope that is 3 m in length. The person weighs 720 N and is in equilibrium. Determine a) the tension of the wire, b) the tension of the rope 2. Relevant equations Since the person is in equilibrium, the resulting Force is 0. The resultant must be the Tension vector of the wire + the tension vector of the rope + the weight vector of person. (R = T_w + T_r + W = 0) T_w = T_w(i) + 0(j) <--- i is the x component, and j is the y component T_r = -T_r(i) + 0(j) W = 0(i) - 720(j) 3. The attempt at a solution Is this right?, is T_w the same magnitude on both sides? |
| Jan22-09, 01:25 AM | #2 |
Recognitions:
Are there any angles involved with this?
I'm not visualizing it from your description. |
| Jan22-09, 10:13 AM | #3 |
Recognitions:
jonnyboy: Are we missing a diagram that goes with this question? If so, could you describe/explain the diagram, and mention any quantities shown on the diagram? The wire is in a V shape, right? Is the rope parallel to the wire? Where is each end of the rope attached? Is the man standing, with his feet apart?
| Jan22-09, 01:39 PM | #4 |
***I added the attachment with the image; the red arrows show the forces acting on the body. The arrow represents the rope force to the left and has a length of 3 meters and the whole wire is 8 meters long. The rope is parallel to the wire. Both the wire and the rope are on the horizontal sense.
| Thread Closed |
| Thread Tools | |
Similar Threads for: Static particle with tension
| Particle-Particle Simulation: Magnetic/Electric Fields & N-body Orbitals | General Physics | 5 | ||
| 2 particle system: Photon + Massive particle | Classical Physics | 6 | ||
| Rope Tension in Static Equilibrium | Introductory Physics Homework | 2 | ||
| Difference between applied tension and tension due to weight? | Introductory Physics Homework | 2 | ||
| is the particle concept in wave-particle duality necessary? | General Physics | 4 | ||
